# Node-RED-Dashboard widget nodes inside UI Builder
**URL:** <https://discourse.nodered.org/t/node-red-dashboard-widget-nodes-inside-ui-builder/32175>\
**Created:** [29 August 2020 07:14 UTC](https://discourse.nodered.org/t/node-red-dashboard-widget-nodes-inside-ui-builder/32175 "2020-08-29T07:14:00Z")\
**Showing post:** 6
**Post date:** [1 September 2020 09:38 UTC](https://discourse.nodered.org/t/node-red-dashboard-widget-nodes-inside-ui-builder/32175/6 "2020-09-01T09:38:41Z")
> [@spillz](#):
> If we could form a small working group where your ideas can be discussed . i can contribute some time into developing it .
Fantastic! Lets start with a new topic here on the forum so that the most people will be able to see and contribute. If that topic gets too big, we can investigate somewhere else to carry on. Watch out for the new topic. I'll paste a link here.
Here is the new topic:
> [@Uibuilder: Component Design + Example Components](https://discourse.nodered.org/t/uibuilder-component-design-discussion/32293):
> Hi all, this topic is to capture ideas and decisions regarding the design of a VueJS component standard for uibuilder. uibuilder VueJS components will be standard pieces of front-end code with an agreed msg schema for communications from/to Node-RED. They will be the uibuilder equivalent of Dashboard widgets. However, where those send the code as well as the data from Node-RED to the front-end, uibuilder components will only send data since the code is developed using standard web development m…
_[View the full topic](https://discourse.nodered.org/t/node-red-dashboard-widget-nodes-inside-ui-builder/32175)._
