# Node-red Error Log File Location
**URL:** <https://discourse.nodered.org/t/node-red-error-log-file-location/83742>\
**Tags:** windows, log\
**Created:** [15 December 2023 11:19 UTC](https://discourse.nodered.org/t/node-red-error-log-file-location/83742 "2023-12-15T11:19:25Z")\
**Post date:** [16 December 2023 07:17 UTC](https://discourse.nodered.org/t/node-red-error-log-file-location/83742/4 "2023-12-16T07:17:56Z")
Windows does not redirect console output to a log file by default
To capture output you need to redirect it:
node-red > node-red-log.log
This will create a new file each time you start node-red
So if you want to append:
node-red >> node-red-log.log
If you want separate logs:
node-red 2>node-red-error.log 1>node-red-log.log
Or if you like to mix outputs (stdout & stderr) in one single file you can use:
node-red > node-red.log 2>&1
_[View the full topic](https://discourse.nodered.org/t/node-red-error-log-file-location/83742)._
