# Node-RED Flows Disappearing
**URL:** <https://discourse.nodered.org/t/node-red-flows-disappearing/34919>\
**Created:** [27 October 2020 23:09 UTC](https://discourse.nodered.org/t/node-red-flows-disappearing/34919 "2020-10-27T23:09:37Z")\
**Post date:** [27 October 2020 23:15 UTC](https://discourse.nodered.org/t/node-red-flows-disappearing/34919/2 "2020-10-27T23:15:39Z")
Hi yes as Nick suggested over there - [🎉 Node-RED 1.2.2 released](https://discourse.nodered.org/t/node-red-1-2-2-released/34528/32) the most likely cause is dhcp on your network giving you a different hostname for your laptop - in the log above - `MacBook-Pro.lan1` - If you look in your ~/.node-red directory you will probably find several different flows\_ files that are the missing ones... you can edit your settings.js file to set the flow file to a fixed name and it won't move again.
_[View the full topic](https://discourse.nodered.org/t/node-red-flows-disappearing/34919)._
