# Node-red in workplace. What are you using it for?
**URL:** <https://discourse.nodered.org/t/node-red-in-workplace-what-are-you-using-it-for/15367>\
**Created:** [10 September 2019 16:17 UTC](https://discourse.nodered.org/t/node-red-in-workplace-what-are-you-using-it-for/15367 "2019-09-10T16:17:27Z")\
**Showing post:** 16
**Post date:** [12 September 2019 07:48 UTC](https://discourse.nodered.org/t/node-red-in-workplace-what-are-you-using-it-for/15367/16 "2019-09-12T07:48:31Z")
Thanks @kuema
I've published some of the students' projects on..
> **[Share Your Projects](https://discourse.nodered.org/c/share-your-projects/6)**
> Share what you’ve done with Node-RED.
The latest one, one of my students is working on, is Building a Solar-Powered Weather Station.
> [@Solar-powered weather station](https://discourse.nodered.org/t/solar-powered-weather-station/12499):
> One of the students in my IoT Computer Club (here in the UK) is working on a personal project to design and build a solar-powered weather station (that will be located in one of the school's gardens) to monitor and report air temperature, humidity and pressure. Here are the [Objectives and list of items.](http://resources-area.co.uk/bohunt-projects/weather-station/objectives.pdf) The student has split the project into six manageable stages. [Using a solar panel to charge a Li-Ion battery and power a Wemos D1 Mini.](http://resources-area.co.uk/bohunt-projects/weather-station/stage_1.pdf)[Putting the Wemos D1 Mini into 'deepsleep' to conserve …](http://resources-area.co.uk/bohunt-projects/weather-station/stage_2.pdf)
_[View the full topic](https://discourse.nodered.org/t/node-red-in-workplace-what-are-you-using-it-for/15367)._
