# Node-red-mcu-plugin v1.0: Integrating Node-RED MCU Edition into the Node-RED editor
**URL:** <https://discourse.nodered.org/t/node-red-mcu-plugin-v1-0-integrating-node-red-mcu-edition-into-the-node-red-editor/72693>\
**Created:** [25 December 2022 19:56 UTC](https://discourse.nodered.org/t/node-red-mcu-plugin-v1-0-integrating-node-red-mcu-edition-into-the-node-red-editor/72693 "2022-12-25T19:56:53Z")\
**Showing post:** 174
**Post date:** [13 March 2023 06:31 UTC](https://discourse.nodered.org/t/node-red-mcu-plugin-v1-0-integrating-node-red-mcu-edition-into-the-node-red-editor/72693/174 "2023-03-13T06:31:23Z")
> [@ralphwetzel](#):
> That calls for some additional issue reports...
With my brand new [cheat sheet](https://discourse.nodered.org/t/input-required-for-a-cheat-sheet-of-node-red-mcu-plugin/76486) I finally understand what you are talking about 🤣
- Do you want me to report those issues in their repo's?
- So both xsbug and xsbug-log are told via the "-x" parameter to run on port 5004 (instead of their default port 5002, but that need to be fixed.
- So we never terminate a running xsbug or xsbug-log via your sidebar. Last week I had accidentally started an xsbug, and afterwards my xs-bug log. Is that asking for troubles? Because I could imagine both would try to listen on the same port 5004? Or when you start when of both, should the script try to terminate automatically a running instance of xsbug OR xsbug-log?
- Is it ok for you if I create an issue for your repo to show somehow the current status in your toolbar? I mean that you see in green "listening" or in red "stopped" or "terminated" or something like that? Because at the moment I don't really have an idea if the setup is currently ok.
Now off to the daily job...
_[View the full topic](https://discourse.nodered.org/t/node-red-mcu-plugin-v1-0-integrating-node-red-mcu-edition-into-the-node-red-editor/72693)._
