# Node red multiple instances
**URL:** <https://discourse.nodered.org/t/node-red-multiple-instances/9787>\
**Category:** Core Development\
**Created:** [5 April 2019 06:09 UTC](https://discourse.nodered.org/t/node-red-multiple-instances/9787 "2019-04-05T06:09:51Z")\
**Showing post:** 5
**Post date:** [6 April 2019 08:12 UTC](https://discourse.nodered.org/t/node-red-multiple-instances/9787/5 "2019-04-06T08:12:48Z")
Instead of changing settings file, I use the -p command line option to specify the port. I also use nssm on windows for multiple instances. So each service launches for example...
- `node-red -p 1881 -u c:/nr1881`
- `node-red -p 1882 -u c:/nr1882`
And so on.
BTW, @knolleary that document you linked to doesn't show the -p option or -t option.
_[View the full topic](https://discourse.nodered.org/t/node-red-multiple-instances/9787)._
