- What version of Node-RED and Node.js are you using? (look at the NR startup log for this info)
- Whch arduino are you using and does it support WiFi?
- what sensor are you using on the arduino to read the temperatures?
- have you coded the code on the arduino yourself or are you using a package like ESPEasy or Tasmoda? If using a package, which one?
- attach a
debugnode (set to display the complete msg object) to the output ofserial-innode. See below for how to do this - export your flow and attach it to a reply. See below for how to do this
How to get data from messages
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
How to post code or flows
code goes here
icon.
