# Node-red-sontrib-s7 ECONNREST error stop node-red
**URL:** <https://discourse.nodered.org/t/node-red-sontrib-s7-econnrest-error-stop-node-red/89104>\
**Created:** [30 June 2024 08:57 UTC](https://discourse.nodered.org/t/node-red-sontrib-s7-econnrest-error-stop-node-red/89104 "2024-06-30T08:57:11Z")\
**Post date:** [30 June 2024 10:45 UTC](https://discourse.nodered.org/t/node-red-sontrib-s7-econnrest-error-stop-node-red/89104/4 "2024-06-30T10:45:37Z")
> [@Lupin\_III](#):
> In this post I see a suggestion that I had in mind, too "One solution would be for you to disable the endpoint when the PLC is not in operation". Is that possibile?
Anything is possible, but you will need to get your hands dirty.
you could fork the code, make the necessary changes then install your fork.
> [@Lupin\_III](#):
> How can I do this.
[How to fork a repository](https://docs.github.com/en/pull-requests/collaborating-with-pull-requests/working-with-forks/fork-a-repo)
[How to install your fork directly from GitHub](https://discourse.nodered.org/t/how-to-install-node-from-github/55549/2)
> [@Lupin\_III](#):
> For what I know the only possibility that exist in order to change from enable/disable node is make this change and redeploy the node. Does it exist an alternative solution?
I dont think so (i've not used that node for a few years)
_[View the full topic](https://discourse.nodered.org/t/node-red-sontrib-s7-econnrest-error-stop-node-red/89104)._
