# Node-Red / sqlite / Charts
**URL:** <https://discourse.nodered.org/t/node-red-sqlite-charts/45251>\
**Created:** [6 May 2021 07:37 UTC](https://discourse.nodered.org/t/node-red-sqlite-charts/45251 "2021-05-06T07:37:04Z")\
**Post date:** [6 May 2021 08:39 UTC](https://discourse.nodered.org/t/node-red-sqlite-charts/45251/2 "2021-05-06T08:39:51Z")
> [@Harakaio](#):
> From sqlite I receive this: Pic1&2.
> Pic1:
If you change your SQL QUERY to only return the `timestamp` and `value` you can feed it into [this function](https://discourse.nodered.org/t/dynamic-series-identification-from-message-send-data-to-chart/36682/5) & it will do most of the work for you. NOTE: it expectes `timestamp` not `Timestamp` - you can either edit the function or change the query (e.g. `select Timestamp as timestamp`)
_[View the full topic](https://discourse.nodered.org/t/node-red-sqlite-charts/45251)._
