# Node-red-ui-table fails when httpNodeAuth enabled
**URL:** <https://discourse.nodered.org/t/node-red-ui-table-fails-when-httpnodeauth-enabled/22425>\
**Created:** [29 February 2020 20:58 UTC](https://discourse.nodered.org/t/node-red-ui-table-fails-when-httpnodeauth-enabled/22425 "2020-02-29T20:58:41Z")\
**Post date:** [1 March 2020 22:03 UTC](https://discourse.nodered.org/t/node-red-ui-table-fails-when-httpnodeauth-enabled/22425/4 "2020-03-01T22:03:19Z")
Despite clearing the browser cache & using an incognito browser, the problem persisted, and was repeatable...
However, after manually deleting the node-RED browser manifest via `chrome://appcache-internals/#` the libraries now load OK, and both this node, and `node-red-contrib-ui-contextmenu` work OK.
> [@\[Announce\] node-red-contrib-ui-contextmenu](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211/22):
> Sorry to be the one to say (again!!) @BartButenaers but it's not working here.. slightly_frowning_face I've configured the node as per the readme, using a simple fixed menu, but it does not appear in the dashboard group. Checking my browser console, I see the following; If I try and load https://nodered.digitalnut.co.uk:8443/ui/ui\_context\_menu/contextmenu.js?\_=1582707759368 in a browser (as per the 401 error above) I get a prompt for auth. If I enter my user/password, then the [con…](https://github.com/bartbutenaers/node-red-contrib-ui-contextmenu/blob/master/lib/contextmenu.js)
_[View the full topic](https://discourse.nodered.org/t/node-red-ui-table-fails-when-httpnodeauth-enabled/22425)._
