# Node-red version 4.09 no file access to my revolution pi directories
**URL:** <https://discourse.nodered.org/t/node-red-version-4-09-no-file-access-to-my-revolution-pi-directories/96971>\
**Created:** [8 May 2025 14:39 UTC](https://discourse.nodered.org/t/node-red-version-4-09-no-file-access-to-my-revolution-pi-directories/96971 "2025-05-08T14:39:08Z")\
**Showing post:** 7
**Post date:** [10 May 2025 12:15 UTC](https://discourse.nodered.org/t/node-red-version-4-09-no-file-access-to-my-revolution-pi-directories/96971/7 "2025-05-10T12:15:26Z")
> [@tim26](#):
> the working directory is '/var/lib/revpi-nodered'.
This is an odd, non-standard location and would have required root/sudo to install there I think. `/var/lib` sub-folders should not, I think, be used as live folders, they are system folders AFAIK.
Actually, thinking about it and having tested my own install, I think that having the working directory as the Node-RED installation folder should be considered a BUG. I'll raise a separate thread to have it discussed.
Anyway, the location is non-standard but does not look like a container folder and does not look like a standard `npm` or Dave's script install either. So to sort this out, as jbudd has asked, we need to know how Node-RED is installed. Without that information, I doubt we can help much more.
_[View the full topic](https://discourse.nodered.org/t/node-red-version-4-09-no-file-access-to-my-revolution-pi-directories/96971)._
