# Node-Red with OpenCV
**URL:** <https://discourse.nodered.org/t/node-red-with-opencv/26067>\
**Created:** [4 May 2020 14:11 UTC](https://discourse.nodered.org/t/node-red-with-opencv/26067 "2020-05-04T14:11:17Z")\
**Post date:** [4 May 2020 17:24 UTC](https://discourse.nodered.org/t/node-red-with-opencv/26067/4 "2020-05-04T17:24:22Z")
..and if you still think you need to use OpenCV in NR, well, I did write about it earlier [here](https://discourse.nodered.org/t/object-detection-using-node-red-contrib-tfjs-coco-ssd/22931/48)
It's a bit time consuming to say the least and if you are looking for using the latest versions of OpenCV, you should check the details in the documentation when installing opencv4nodejs. It takes very long time to build OpenCV from source on a RPi3, so boring. But it depends on what kind of features you are looking for
_[View the full topic](https://discourse.nodered.org/t/node-red-with-opencv/26067)._
