wow .. thanks .. now nodemcu and the broker is on same network and works perfectly
thanks got it
thanks now nodemcu connected to mqtt broker after i connect them to same network
but connection not stable ,, getting into reconnect mode and get connect , work for sometime then again disconnect and try to reconnect .. any solution for that
Thankyou everyone for expert advice .. I finally able to connect iot to nodered through mqtt broker. I appreciate everyone's help and advice .. This makes my more interest in node-red.
Sounds like that could be a WiFi strength issue.
Could you try moving the NodeMCU nearer to the acess point and see if the reconnections reduce/stop??
The suggestion from @krambriw about using a broker on the Cloud is a good one.
I use BeeBotte for my remote weather stations and have two MQTT-In nodes in Node-RED.
One is listening for traffic from my home network and the other for remote traffic from the Cloud.
I just make server for testing .. for future sure going to use some stable and powerful one
I am new to node-red but definately going to go for more in it .. I am going to disturb you alot in future .. haha
Where are you seeing this? In NR or in the nodemcu? (details are important)
This is most likely due to the 'keep alive' interval. If you haven't read it yet. I suggest you read hivehq.com' Tags and the part
What Is MQTT Keep Alive and Client Take-Over? – MQTT Essentials Part 10
That's the issue from nodemcu side ..thanks for the link.
