NodeRed MQTT bridge?
What kind of VPN setup? A VPN between 2 sites would normally mean that both local networks are connected and you shouldn't need an external address - indeed, the whole point is that routing over the VPN is a local route.
The only reason this wouldn't be the case is if you are using a consumer VPN provider at both ends. That is a different kind of VPN (one that lets you appear to be in a different country for example).
Just a thought... Are you sure that all connections to Mosquitto use a unique MQTT Client ID? Otherwise it will kill the existing connection when a different connection is opened with the same Client ID.
You can also just do this. Set up the left side to broker 1 and fill out the topic as Topic/# and the right side set up for broker 2 and leave the topic blank. This will cause everything from broker 1 under topic to be sent to broker 2 under that same topic. It's a great way to aggregate data from a bunch of small brokers on the same subnet to a large broker in the cloud without setting up credentials for each individual smaller broker.
That only works in one direction. The OP wanted to bridge in both directions at the same time.
