# Nodes suggestion for timed rolling average and desynchronised sum
**URL:** <https://discourse.nodered.org/t/nodes-suggestion-for-timed-rolling-average-and-desynchronised-sum/4933>\
**Created:** [16 November 2018 12:38 UTC](https://discourse.nodered.org/t/nodes-suggestion-for-timed-rolling-average-and-desynchronised-sum/4933 "2018-11-16T12:38:44Z")\
**Showing post:** 17
**Post date:** [18 November 2018 12:15 UTC](https://discourse.nodered.org/t/nodes-suggestion-for-timed-rolling-average-and-desynchronised-sum/4933/17 "2018-11-18T12:15:02Z")
Unfortunately your flow is not importable. You need to use this technique to paste a flow here
Also it is best to click the Compact view on the export dialog so it all appears as a single line here so is much easier to mark for copying.
_[View the full topic](https://discourse.nodered.org/t/nodes-suggestion-for-timed-rolling-average-and-desynchronised-sum/4933)._
