# Noob set flow variable question
**URL:** <https://discourse.nodered.org/t/noob-set-flow-variable-question/40245>\
**Created:** [2 February 2021 14:57 UTC](https://discourse.nodered.org/t/noob-set-flow-variable-question/40245 "2021-02-02T14:57:10Z")\
**Post date:** [2 February 2021 15:27 UTC](https://discourse.nodered.org/t/noob-set-flow-variable-question/40245/4 "2021-02-02T15:27:31Z")
You cannot do a 'set if not defined' type of rule in the Change node, but aside from that, you can set a flow context value. In the screenshot you've shared, I can see you were using `msg.paylod` and not `msg.payload`.
_[View the full topic](https://discourse.nodered.org/t/noob-set-flow-variable-question/40245)._
