# Npm error - mobius-flow-base, Tasmota, EnOcean PTM215B
**URL:** <https://discourse.nodered.org/t/npm-error-mobius-flow-base-tasmota-enocean-ptm215b/27611>\
**Created:** [1 June 2020 10:29 UTC](https://discourse.nodered.org/t/npm-error-mobius-flow-base-tasmota-enocean-ptm215b/27611 "2020-06-01T10:29:57Z")\
**Showing post:** 3
**Author:** ![stefan24](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/stefan24/32/23075_2.png) [@stefan24](https://discourse.nodered.org/u/stefan24)\
**Post date:** [1 June 2020 18:01 UTC](https://discourse.nodered.org/t/npm-error-mobius-flow-base-tasmota-enocean-ptm215b/27611/3 "2020-06-01T18:01:17Z")
Welcome to the forum!
1. from [https://nodered.org/docs/getting-started/raspberrypi](https://nodered.org/docs/getting-started/raspberrypi)
### Autostart on boot
If you want Node-RED to run when the Pi is turned on, or re-booted, you can enable the service to autostart by running the command:
sudo systemctl enable nodered.service
1. install your tasmota devices and the Enocean / bluetooth button seperately. However I had problems with the enocean node and the tasmota node at the same time. see [Tasmota node not working after Tasmota 8.30 firmware update?](https://discourse.nodered.org/t/tasmota-node-not-working-after-tasmota-8-30-firmware-update/26740)
Finally I used the tasmota plugs via MQTT and could use a Enocean based Hoppe door handle with my Enocean USB 300 stick and the enocean node.
I do not understand if that PTM 215B uses Enocean or bluetooth or both and whether it can be integrated in Node-RED at all.
Your screenshots indicate, that you may be not in the right directory when installing the additional nodes. If you installed Node-RED with the script from [https://nodered.org/docs/getting-started/raspberrypi](https://nodered.org/docs/getting-started/raspberrypi), you should change the directory to ~/.node-red, before you start `npm install ...`
_[View the full topic](https://discourse.nodered.org/t/npm-error-mobius-flow-base-tasmota-enocean-ptm215b/27611)._
