# NRD to Influxdb-strings
**URL:** <https://discourse.nodered.org/t/nrd-to-influxdb-strings/53315>\
**Created:** [6 November 2021 23:40 UTC](https://discourse.nodered.org/t/nrd-to-influxdb-strings/53315 "2021-11-06T23:40:37Z")\
**Author:** ![grant1](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/grant1/32/49890_2.png) [@grant1](https://discourse.nodered.org/u/grant1)\
**Post date:** [7 November 2021 11:11 UTC](https://discourse.nodered.org/t/nrd-to-influxdb-strings/53315/2 "2021-11-07T11:11:33Z")
07/11/2021, 10:33:16node: 8127b9f1260f2605
Sys4/ORP/add98/ORPsys4 : msg.payload : string[2]
"77"
As I understand it, you just want the "77" from the above output, which as you noted is a string. I had a similar question and I learned you can use a change node, regex, or match to 'extract' the value you want. See [here](https://discourse.nodered.org/t/split-string-into-text-and-integers/49889/8).
_[View the full topic](https://discourse.nodered.org/t/nrd-to-influxdb-strings/53315)._
