NRG Sentinel, runtime security for Node-RED
When uninstalling a package that has its types referenced in flows, a warning appears. You also have to type the package name before uninstalling it.
I released all changes as v1.1.0 (patched already so try v1.1.1)
There are breaking changes to the schema of the grants!
v1 is being treated as my v0 so breaking changes without major bumps will happen.
Don't try using it with huge packages like the dashboard 2.0 until you understand how each grant affects the runtime package boundaries.
Ensure you have docker installed to be able to install packages safely using an ephemeral container. By default none of the scripts hooks that packages ship will run when installing packages. This might break dependencies that use them.
There are other vulnerabilities that I identified that I will try to fix later, like transitive dependencies registering nodes before the real one does
The admin and flow diff apps both work out of the box with the standard auth module. When the auth module is configured these apps require auth token with admin scope.
Weโ€™re planning to use this with our self-hosted FlowFuse setup at the company. Do you have any documentation or a step-by-step tutorial we could follow to get started?
Not supported, yet. Maybe in the future.
Just added a small script to help you get started with NRG Sentinel
