# Object Detection using node-red-contrib-tfjs-coco-ssd
**URL:** <https://discourse.nodered.org/t/object-detection-using-node-red-contrib-tfjs-coco-ssd/22931>\
**Created:** [10 March 2020 14:41 UTC](https://discourse.nodered.org/t/object-detection-using-node-red-contrib-tfjs-coco-ssd/22931 "2020-03-10T14:41:53Z")\
**Showing post:** 116
**Post date:** [13 April 2020 08:29 UTC](https://discourse.nodered.org/t/object-detection-using-node-red-contrib-tfjs-coco-ssd/22931/116 "2020-04-13T08:29:50Z")
> [@krambriw](#):
> I have some ideas experimenting
So I managed to make the coco-ssd-node work on Jetson Nano!!! This is how it worked for me:
Install both nodes:
- node-red-contrib-tf-model
(following the guide referenced already above [GitHub - yhwang/node-red-contrib-tf-model: A Node-RED node to load tensorflow model](https://github.com/yhwang/node-red-contrib-tf-model#note) )
- node-red-contrib-tfjs-coco-ssd
In the folder "/home/user/.node-red/node\_modules/node-red-contrib-tfjs-coco-ssd/node\_modules/@tensorflow" delete the following folders
- tfjs-node
- tfjs-converter
and then replace with the same folders from the folder "/home/user/.node-red/node\_modules/@tensorflow"
After this the coco-ssd node also works on arm64!
![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/6/a/6adee7fe795c95263790c9ef3434c9ed844caa3f.png)
_[View the full topic](https://discourse.nodered.org/t/object-detection-using-node-red-contrib-tfjs-coco-ssd/22931)._
