# Object to number Conversion
**URL:** <https://discourse.nodered.org/t/object-to-number-conversion/24807>\
**Created:** [14 April 2020 12:16 UTC](https://discourse.nodered.org/t/object-to-number-conversion/24807 "2020-04-14T12:16:49Z")\
**Post date:** [14 April 2020 12:36 UTC](https://discourse.nodered.org/t/object-to-number-conversion/24807/2 "2020-04-14T12:36:13Z")
Hi @Robbie98
can you share what the Debug output shows for the message coming from the SenseHat node? If I remember the node correctly (I did write it....), it sends a payload of `{temperature: 12}`.
I can see you have added a JSON node - that will be converting the object to a string. That will make it harder to access the individual values inside the string.
I _think_ you just need the Change node between the SenseHat node and the gauge node, configured to set `msg.payload` to `msg.payload.temperature`.
_[View the full topic](https://discourse.nodered.org/t/object-to-number-conversion/24807)._
