# Onvif camera control
**URL:** https://discourse.nodered.org/t/onvif-camera-control/6888
**Category:** General
**Created:** [16 January 2019 14:24 UTC](https://discourse.nodered.org/t/onvif-camera-control/6888 "2019-01-16T14:24:51Z")
**Showing post:** 24
#### Post date: [21 January 2019 22:36 UTC](https://discourse.nodered.org/t/onvif-camera-control/6888/24 "2019-01-21T22:36:15Z")
@davidcgu,
It takes a bit longer as expected:
- Apperently some of the Onvif nodes that I had build last summer, were still based on the node-onvif library instead of the onvif library. Have updated the code, but need to test all commands.
- I need to optimize the communication between Node-RED and the camera, to ensure that the number of requests to the camera is minimized. And this makes my code also cleaner. But need to get first some feeback on this [issue](https://discourse.nodered.org/t/listening-to-config-node-events/7117).
- Seems that our friend @wb666greene is looking at PT cameras instead of PTZ. Since I have also PT cameras, I really need to create a pull request for the Onvif library (otherwise e.g. we cannot determine the current position of the camera in both directions): indeed an exception occurs when the camera only returns PT info but no Z(oom) info ...
But we will get there soon ...
_[View the full topic](https://discourse.nodered.org/t/onvif-camera-control/6888)._
