If all the data is in the same row you don’t need to create three paths and eventually do a join. You could do the calculation in just one function node.
let l = msg.payload.col6;
node.warn("col6="+l);
let t = msg.payload.col10;
node.warn("col10="+t);
let h = msg.payload.col11;
node.warn("col11="+h);
let LSVP = (Math.pow(2.71828,(l / (l +238.3) * 17.2694))* 610.78)/1000;
let SVP = (Math.pow(2.71828,(t / (t +238.3) * 17.2694))* 610.78)/1000;
h = Math.round(h * 100*10)/10;
let DDP = LSVP-(SVP*h/100);
msg.lsvp = LSVP;
msg.svp = SVP;
msg.h = h;
msg.payload=DDP
send the output of the csv to a function node with the above code and send the putput to a debug node to see the results.
Here is some reading that might make things clearer
Canned replies:
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
