# Payload name - not going through function node
**URL:** <https://discourse.nodered.org/t/payload-name-not-going-through-function-node/63073>\
**Created:** [25 May 2022 20:48 UTC](https://discourse.nodered.org/t/payload-name-not-going-through-function-node/63073 "2022-05-25T20:48:41Z")\
**Post date:** [26 May 2022 00:45 UTC](https://discourse.nodered.org/t/payload-name-not-going-through-function-node/63073/4 "2022-05-26T00:45:41Z")
Ahh I was going to tell you that you needed to fix the flow but I see you have removed it. Did you solve your issue?
P.S.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/payload-name-not-going-through-function-node/63073)._
