# Pi, Level shifter, ADS1115, MPX differential sensor wiring questions
**URL:** <https://discourse.nodered.org/t/pi-level-shifter-ads1115-mpx-differential-sensor-wiring-questions/63427>\
**Created:** [3 June 2022 15:49 UTC](https://discourse.nodered.org/t/pi-level-shifter-ads1115-mpx-differential-sensor-wiring-questions/63427 "2022-06-03T15:49:45Z")\
**Showing post:** 32
**Author:** ![9toejack](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/9toejack/32/56868_2.png) [@9toejack](https://discourse.nodered.org/u/9toejack)\
**Post date:** [7 June 2022 19:13 UTC](https://discourse.nodered.org/t/pi-level-shifter-ads1115-mpx-differential-sensor-wiring-questions/63427/32 "2022-06-07T19:13:01Z")
@WBr
here is the start of tutorial, hopefully this can get you going on installing tasmota onto the esp8266.
also another good note the Esp8266 has a pull up resistor built in, this can be enabled when using DS18b20's
> [@How to install Tasmota on an ESP8266](https://discourse.nodered.org/t/how-to-install-tasmota-on-an-esp8266/63587):
> How to set up an esp8266 with Tasmota, and collect data from pressure sensors, humidity, and temperature sensors, and use Node Red Dashboard to display your readings. Things you will need. 1 A raspberry pi with Node Red and MQTT installed an Esp8266 a terminal block dev kit for the esp8266 some solder bread boards. some wire and sockets to solder to breadboard I use 4 wire phone line ( I also use it to extend the lines of the DS18b20’s and the Pressure sensors. it also ma…
_[View the full topic](https://discourse.nodered.org/t/pi-level-shifter-ads1115-mpx-differential-sensor-wiring-questions/63427)._
