Power Forecasts and Data-Tuning for Solar Installations (Node-Red / solcast-API / InfluxDB / Grafana)
Here`s a partial update, with a separate flow that would allow to create calls to the API (forecasts and estimated_actuals) between times at an equidistant interval.
[{"id":"1fd8cac4.8f5445","type":"tab","label":"solcast timer","disabled":false,"info":""},{"id":"313aadae.e6d532","type":"sun-position","z":"1fd8cac4.8f5445","name":"suncalc forecasts","positionConfig":"8c7609ce.dd5798","rules":[],"onlyOnChange":"true","topic":"suncalc-1","outputs":1,"start":"sunrise","startType":"pdsTime","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"end":"sunset","endType":"pdsTime","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"x":514,"y":100,"wires":[["5f40d18.f5a843"]]},{"id":"5551575d.3a2058","type":"time-inject","z":"1fd8cac4.8f5445","name":"","nameInt":"⏲ Sonnenaufgang Begin = Zeitpunkt","positionConfig":"8c7609ce.dd5798","payload":"","payloadType":"date","payloadTimeFormat":0,"payloadOffset":0,"payloadOffsetType":"none","payloadOffsetMultiplier":60000,"topic":"start","injectTypeSelect":"time","intervalCount":1,"intervalCountType":"num","intervalCountMultiplier":60000,"time":"sunrise","timeType":"pdsTime","offset":0,"offsetType":"none","offsetMultiplier":60000,"timeEnd":"","timeEndType":"entered","timeEndOffset":0,"timeEndOffsetType":"none","timeEndOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","property":"","propertyType":"none","propertyCompare":"true","propertyThreshold":"","propertyThresholdType":"num","timeAlt":"","timeAltType":"entered","timeAltDays":"*","timeAltOnlyOddDays":false,"timeAltOnlyEvenDays":false,"timeAltMonths":"*","timeAltOffset":0,"timeAltOffsetType":"none","timeAltOffsetMultiplier":60000,"once":false,"onceDelay":0.1,"addPayload1":"","addPayload1Type":"none","addPayload1Value":"","addPayload1ValueType":"date","addPayload1Format":"0","addPayload1Offset":0,"addPayload1OffsetType":"none","addPayload1OffsetMultiplier":60000,"addPayload1Next":true,"addPayload1Days":"*","addPayload2":"","addPayload2Type":"none","addPayload2Value":"","addPayload2ValueType":"date","addPayload2Format":"0","addPayload2Offset":0,"addPayload2OffsetType":"none","addPayload2OffsetMultiplier":60000,"addPayload2Next":true,"addPayload2Days":"*","addPayload3":"","addPayload3Type":"none","addPayload3Value":"","addPayload3ValueType":"date","addPayload3Format":"0","addPayload3Offset":0,"addPayload3OffsetType":"none","addPayload3OffsetMultiplier":60000,"addPayload3Next":true,"addPayload3Days":"*","recalcTime":2,"x":220,"y":220,"wires":[["132cc14d.35a44f","9354a22a.97b1","33de93bc.8926cc","8b30894a.3f0618"]]},{"id":"9729d616.48af08","type":"time-inject","z":"1fd8cac4.8f5445","name":"","nameInt":"⏲ Sonnenuntergang Ende↷ = Zeitpunkt","positionConfig":"8c7609ce.dd5798","payload":"","payloadType":"date","payloadTimeFormat":0,"payloadOffset":0,"payloadOffsetType":"none","payloadOffsetMultiplier":60000,"topic":"stop","injectTypeSelect":"time","intervalCount":1,"intervalCountType":"num","intervalCountMultiplier":60000,"time":"sunset","timeType":"pdsTime","offset":"15","offsetType":"num","offsetMultiplier":60000,"timeEnd":"","timeEndType":"entered","timeEndOffset":0,"timeEndOffsetType":"none","timeEndOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","property":"","propertyType":"none","propertyCompare":"true","propertyThreshold":"","propertyThresholdType":"num","timeAlt":"","timeAltType":"entered","timeAltDays":"*","timeAltOnlyOddDays":false,"timeAltOnlyEvenDays":false,"timeAltMonths":"*","timeAltOffset":0,"timeAltOffsetType":"none","timeAltOffsetMultiplier":60000,"once":false,"onceDelay":0.1,"addPayload1":"","addPayload1Type":"none","addPayload1Value":"","addPayload1ValueType":"date","addPayload1Format":"0","addPayload1Offset":0,"addPayload1OffsetType":"none","addPayload1OffsetMultiplier":60000,"addPayload1Next":true,"addPayload1Days":"*","addPayload2":"","addPayload2Type":"none","addPayload2Value":"","addPayload2ValueType":"date","addPayload2Format":"0","addPayload2Offset":0,"addPayload2OffsetType":"none","addPayload2OffsetMultiplier":60000,"addPayload2Next":true,"addPayload2Days":"*","addPayload3":"","addPayload3Type":"none","addPayload3Value":"","addPayload3ValueType":"date","addPayload3Format":"0","addPayload3Offset":0,"addPayload3OffsetType":"none","addPayload3OffsetMultiplier":60000,"addPayload3Next":true,"addPayload3Days":"*","recalcTime":2,"x":240,"y":300,"wires":[["9354a22a.97b1","33de93bc.8926cc"]]},{"id":"5b62f0eb.a59f","type":"inject","z":"1fd8cac4.8f5445","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"inject","payload":"0","payloadType":"str","x":150,"y":100,"wires":[["313aadae.e6d532"]]},{"id":"5f40d18.f5a843","type":"change","z":"1fd8cac4.8f5445","name":"set interval (forecasts)","rules":[{"t":"set","p":"iterations","pt":"msg","to":"8","tot":"num"},{"t":"set","p":"intervalLength","pt":"msg","to":"payload.endTime - payload.startTime","tot":"jsonata"},{"t":"set","p":"interval","pt":"msg","to":"$ceil(intervalLength / (iterations-1))","tot":"jsonata"},{"t":"move","p":"interval","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"interval","tot":"str"},{"t":"delete","p":"iterations","pt":"msg"},{"t":"delete","p":"intervalLength","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":100,"wires":[["9354a22a.97b1"]]},{"id":"d2a66d94.cdde6","type":"link out","z":"1fd8cac4.8f5445","name":"timer estimates","links":["26296625.2bcada"],"x":1415,"y":400,"wires":[]},{"id":"b2c4ddba.9457d","type":"link out","z":"1fd8cac4.8f5445","name":"timer forecasts","links":["fd68fcd0.4f817"],"x":1415,"y":100,"wires":[]},{"id":"6bc9fd1b.c3df54","type":"inject","z":"1fd8cac4.8f5445","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"inject","payload":"0","payloadType":"num","x":170,"y":400,"wires":[["d3131449.ea8408"]]},{"id":"d3131449.ea8408","type":"sun-position","z":"1fd8cac4.8f5445","name":"suncalc estimates","positionConfig":"8c7609ce.dd5798","rules":[],"onlyOnChange":"true","topic":"suncalc-2","outputs":1,"start":"sunrise","startType":"pdsTime","startOffset":"-2","startOffsetType":"num","startOffsetMultiplier":"3600000","end":"sunset","endType":"pdsTime","endOffset":0,"endOffsetType":"none","endOffsetMultiplier":60000,"x":510,"y":400,"wires":[["ab80d6ae.e5ecf8"]]},{"id":"8c4daa98.397c78","type":"change","z":"1fd8cac4.8f5445","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"},{"t":"set","p":"topic","pt":"msg","to":"forecasts","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1240,"y":100,"wires":[["b2c4ddba.9457d"]]},{"id":"2dce9a6.1fbc666","type":"change","z":"1fd8cac4.8f5445","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"},{"t":"set","p":"topic","pt":"msg","to":"estimated_actuals","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1240,"y":400,"wires":[["d2a66d94.cdde6"]]},{"id":"9354a22a.97b1","type":"dsm","z":"1fd8cac4.8f5445","name":"interval","sm_config":"{\n    \"stateOutput\": \"state\",\n    \"currentState\": \"stopped\",\n    \"states\": {\n        \"stopped\": {\n            \"start\": \"started\"\n        },\n        \"started\": {\n            \"run\": \"running\",\n            \"stop\": \"stopped\"\n        },\n        \"running\": {\n            \"run\": \"running\",\n            \"stop\": \"stopped\"\n        }\n    },\n    \"data\": {\n        \"interval\": 2000\n    },\n    \"methods\": {\n        \"interval\": {\n            \"name\": \"setData\"\n        },\n        \"start\":  [\n            \"if (sm.currentState === 'started') {\",\n            \"   node.send(msg);\",\n            \"   resume('run',msg);\",\n            \"}\"\n        ],\n        \"run\": [\n            \"timeout.interval = setTimeout(function() {\",\n            \"   node.send(msg);\",\n            \"   resume('run',msg);\",\n            \"}, sm.data.interval);\"\n        ],\n        \"stop\": [\n            \"if (timeout.interval) {\",\n            \"   clearTimeout(timeout.interval);\",\n            \"}\"\n        ],\n        \"onAfterTransition\": \"output = false;\",\n        \"status\": {\n            \"fill\": {\n                \"get\": \"sm.currentState === 'running' ? 'green' : 'grey'\"\n            },\n            \"shape\": \"dot\",\n            \"text\": {\n                \"get\": \"sm.currentState === 'running' ? 'interval ' + sm.data.interval : sm.currentState\"\n            }\n        }\n    }\n}","x":1020,"y":220,"wires":[["8f1bbf80.3c69f","8c4daa98.397c78"]]},{"id":"33de93bc.8926cc","type":"dsm","z":"1fd8cac4.8f5445","name":"interval","sm_config":"{\n    \"stateOutput\": \"state\",\n    \"currentState\": \"stopped\",\n    \"states\": {\n        \"stopped\": {\n            \"start\": \"started\"\n        },\n        \"started\": {\n            \"run\": \"running\",\n            \"stop\": \"stopped\"\n        },\n        \"running\": {\n            \"run\": \"running\",\n            \"stop\": \"stopped\"\n        }\n    },\n    \"data\": {\n        \"interval\": 2000\n    },\n    \"methods\": {\n        \"interval\": {\n            \"name\": \"setData\"\n        },\n        \"start\":  [\n            \"if (sm.currentState === 'started') {\",\n            \"   node.send(msg);\",\n            \"   resume('run',msg);\",\n            \"}\"\n        ],\n        \"run\": [\n            \"timeout.interval = setTimeout(function() {\",\n            \"   node.send(msg);\",\n            \"   resume('run',msg);\",\n            \"}, sm.data.interval);\"\n        ],\n        \"stop\": [\n            \"if (timeout.interval) {\",\n            \"   clearTimeout(timeout.interval);\",\n            \"}\"\n        ],\n        \"onAfterTransition\": \"output = false;\",\n        \"status\": {\n            \"fill\": {\n                \"get\": \"sm.currentState === 'running' ? 'green' : 'grey'\"\n            },\n            \"shape\": \"dot\",\n            \"text\": {\n                \"get\": \"sm.currentState === 'running' ? 'interval ' + sm.data.interval : sm.currentState\"\n            }\n        }\n    }\n}","x":1020,"y":280,"wires":[["8f1bbf80.3c69f","2dce9a6.1fbc666"]]},{"id":"ab80d6ae.e5ecf8","type":"change","z":"1fd8cac4.8f5445","name":"set interval (estimates)","rules":[{"t":"set","p":"iterations","pt":"msg","to":"8","tot":"num"},{"t":"set","p":"intervalLength","pt":"msg","to":"payload.endTime - payload.startTime","tot":"jsonata"},{"t":"set","p":"interval","pt":"msg","to":"$ceil(intervalLength / (iterations-1))","tot":"jsonata"},{"t":"move","p":"interval","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"topic","pt":"msg","to":"interval","tot":"str"},{"t":"delete","p":"iterations","pt":"msg"},{"t":"delete","p":"intervalLength","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":800,"y":400,"wires":[["33de93bc.8926cc"]]},{"id":"132cc14d.35a44f","type":"delay","z":"1fd8cac4.8f5445","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":320,"y":160,"wires":[["313aadae.e6d532"]]},{"id":"8b30894a.3f0618","type":"delay","z":"1fd8cac4.8f5445","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":380,"y":347,"wires":[["d3131449.ea8408"]]},{"id":"8f1bbf80.3c69f","type":"debug","z":"1fd8cac4.8f5445","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1330,"y":240,"wires":[]},{"id":"8c7609ce.dd5798","type":"position-config","z":"","name":"DACH-1","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":"99","timeZoneDST":"0","stateTimeFormat":"3","stateDateFormat":"12"}]
...it makes use of the sun-position (https://flows.nodered.org/node/node-red-contrib-sun-position) node, as well as dsm node with interval configuration (https://github.com/cflurin/node-red-contrib-dsm/wiki/Interval).
Combine it with a slightly modified version of flow B, from above.
[{"id":"32266837.fdbe88","type":"tab","label":"solcast API","disabled":false,"info":""},{"id":"21f2593a.771e66","type":"http request","z":"32266837.fdbe88","name":"Solcast API - get Live+Forecast JSON","method":"GET","ret":"obj","paytoqs":false,"url":"https://api.solcast.com.au/rooftop_sites/<your-rooftop-id-here>/forecasts?format=json","tls":"","persist":false,"proxy":"","authType":"basic","x":922,"y":460,"wires":[["a6c53186.54f16"]]},{"id":"6abdc0ec.b0703","type":"debug","z":"32266837.fdbe88","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1370,"y":520,"wires":[]},{"id":"ba47e82d.894b58","type":"http request","z":"32266837.fdbe88","name":"Solcast API - get Past + Estimated Actuals","method":"GET","ret":"obj","paytoqs":false,"url":"https://api.solcast.com.au/rooftop_sites/<your-rooftop-id-here>/estimated_actuals?format=json","tls":"","persist":false,"proxy":"","authType":"basic","x":720,"y":320,"wires":[["a6c53186.54f16"]]},{"id":"a6c53186.54f16","type":"switch","z":"32266837.fdbe88","name":"StatusCode","property":"statusCode","propertyType":"msg","rules":[{"t":"eq","v":"200","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1199,"y":460,"wires":[["be5f401f.66f5c"],["6abdc0ec.b0703","e6e348ec.18b858"]]},{"id":"de74762b.088578","type":"split","z":"32266837.fdbe88","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":867,"y":160,"wires":[["b7a911ed.41d26"]]},{"id":"5df49bf4.59df34","type":"join","z":"32266837.fdbe88","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1234,"y":159,"wires":[["5afa3e4e.b475f","cbb479d8.451368"]]},{"id":"b7a911ed.41d26","type":"change","z":"32266837.fdbe88","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[[\t{\"value\": $.payload.pv_estimate * 1000,\t\"time\": $toMillis($.payload.period_end) - 1800000},\t{\"topic\": \"pv_estimate\"}\t],\t[\t{\"value\": $.payload.pv_estimate10 * 1000,\t\"time\": $toMillis($.payload.period_end) - 1800000},\t{\"topic\": \"pv_estimate10\"}\t],\t[\t{\"value\": $.payload.pv_estimate90 * 1000,\t\"time\": $toMillis($.payload.period_end) - 1800000},\t{\"topic\": \"pv_estimate90\"}\t]\t]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1027,"y":160,"wires":[["5df49bf4.59df34","264bbb44.61e064"]]},{"id":"264bbb44.61e064","type":"influxdb out","z":"32266837.fdbe88","influxdb":"e07787.cd769878","name":"solcast","measurement":"solcast","precision":"ms","retentionPolicy":"","x":1224,"y":103,"wires":[]},{"id":"e6e348ec.18b858","type":"change","z":"32266837.fdbe88","name":"timestamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"},{"t":"delete","p":"statusCode","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":750,"y":380,"wires":[["ae447bdd.ffe208"]]},{"id":"ae447bdd.ffe208","type":"delay","z":"32266837.fdbe88","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":640,"y":460,"wires":[["c59bea9b.7ae128","becb3de9.218db"]]},{"id":"21b9fd1e.1b65b2","type":"within-time-switch","z":"32266837.fdbe88","name":"neuer Tag?","nameInt":"","positionConfig":"8c7609ce.dd5798","startTime":"sunrise","startTimeType":"pdsTime","startOffset":"-15","startOffsetType":"num","startOffsetMultiplier":60000,"endTime":"sunset","endTimeType":"pdsTime","endOffset":"30","endOffsetType":"num","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":304,"y":422,"wires":[["c59bea9b.7ae128"],["5a6a78b2.1bb548"]]},{"id":"5f5faa37.8a57a4","type":"inject","z":"32266837.fdbe88","name":"forecasts","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"forecasts","payload":"","payloadType":"date","x":126,"y":735,"wires":[["c59bea9b.7ae128"]]},{"id":"5a6a78b2.1bb548","type":"change","z":"32266837.fdbe88","name":"reset counter","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"topic.reset","pt":"msg","to":"reset","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":470,"y":619,"wires":[["c59bea9b.7ae128","cbb479d8.451368","42c07bc5.59caa4","becb3de9.218db"]]},{"id":"c59bea9b.7ae128","type":"counter","z":"32266837.fdbe88","name":"Counter","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":739,"y":619,"wires":[["65b9dc96.ae3184","dfaff625.bb0808"]]},{"id":"42b74548.b7641c","type":"switch","z":"32266837.fdbe88","name":"counter","property":"count","propertyType":"msg","rules":[{"t":"btwn","v":"1","vt":"num","v2":"20","v2t":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1109,"y":619,"wires":[["6b7ba7c6.8cd608"],["6abdc0ec.b0703"]]},{"id":"65b9dc96.ae3184","type":"change","z":"32266837.fdbe88","name":"","rules":[{"t":"delete","p":"reset","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":927,"y":619,"wires":[["42b74548.b7641c"]]},{"id":"be5f401f.66f5c","type":"switch","z":"32266837.fdbe88","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"estimated_actuals","vt":"str"},{"t":"eq","v":"forecasts","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":370,"y":100,"wires":[["2d9205e4.b6f57a"],["686ddd2f.0bcc64"]]},{"id":"5e3c32f5.6a245c","type":"split","z":"32266837.fdbe88","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":870,"y":41,"wires":[["7aca0184.04cd8"]]},{"id":"7aca0184.04cd8","type":"change","z":"32266837.fdbe88","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[\t{\"value\": $.payload.pv_estimate * 1000,\t\"time\": $toMillis($.payload.period_end) - 1800000},\t{\"topic\": \"pv_estimate\"}\t]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1032,"y":41,"wires":[["ac93c718.446698","264bbb44.61e064"]]},{"id":"383e8c45.6f01e4","type":"inject","z":"32266837.fdbe88","name":"tägl. 02:00Uhr","repeat":"","crontab":"00 02 * * *","once":false,"onceDelay":0.1,"topic":"Counter_Reset","payload":"","payloadType":"date","x":147,"y":581,"wires":[["21b9fd1e.1b65b2"]]},{"id":"6b7ba7c6.8cd608","type":"switch","z":"32266837.fdbe88","name":"topic","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"estimated_actuals","vt":"str"},{"t":"eq","v":"forecasts","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":490,"y":372,"wires":[["ba47e82d.894b58"],["21f2593a.771e66"]]},{"id":"5a8f1cb1.deed44","type":"inject","z":"32266837.fdbe88","name":"estimated_actuals","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"estimated_actuals","payload":"","payloadType":"date","x":155,"y":793,"wires":[["c59bea9b.7ae128"]]},{"id":"7f1c965b.e60e98","type":"comment","z":"32266837.fdbe88","name":"Manuelle Abfragen","info":"","x":146,"y":695,"wires":[]},{"id":"73a068c2.669b08","type":"comment","z":"32266837.fdbe88","name":"Zeitgesteuerte Abfragen","info":"","x":160,"y":300,"wires":[]},{"id":"2a3f1855.356228","type":"comment","z":"32266837.fdbe88","name":"API abfragen","info":"","x":970,"y":380,"wires":[]},{"id":"64b0e77c.d73928","type":"comment","z":"32266837.fdbe88","name":"InfluxDB füllen","info":"","x":370,"y":60,"wires":[]},{"id":"a5d6bcfd.2549e","type":"comment","z":"32266837.fdbe88","name":"1-20 API-Calls pro Tag möglich","info":"","x":895,"y":580,"wires":[]},{"id":"ac93c718.446698","type":"join","z":"32266837.fdbe88","name":"","mode":"auto","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1234,"y":41,"wires":[["5afa3e4e.b475f","42c07bc5.59caa4"]]},{"id":"5afa3e4e.b475f","type":"debug","z":"32266837.fdbe88","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1389,"y":120,"wires":[]},{"id":"686ddd2f.0bcc64","type":"change","z":"32266837.fdbe88","name":"","rules":[{"t":"move","p":"payload.forecasts","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":660,"y":160,"wires":[["de74762b.088578"]]},{"id":"2d9205e4.b6f57a","type":"change","z":"32266837.fdbe88","name":"","rules":[{"t":"move","p":"payload.estimated_actuals","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":41,"wires":[["5e3c32f5.6a245c"]]},{"id":"ab24add7.baf8","type":"comment","z":"32266837.fdbe88","name":"API-Call Counter rücksetzen","info":"","x":159,"y":541,"wires":[]},{"id":"d8311a4.20934e8","type":"inject","z":"32266837.fdbe88","name":"Counter_Reset","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Counter_Reset","payload":"","payloadType":"date","x":146,"y":618,"wires":[["5a6a78b2.1bb548"]]},{"id":"dfaff625.bb0808","type":"debug","z":"32266837.fdbe88","name":"total requests","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"count","targetType":"msg","x":1060,"y":500,"wires":[]},{"id":"42c07bc5.59caa4","type":"counter","z":"32266837.fdbe88","name":"Counter","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":1260,"y":220,"wires":[["657c722f.c5c9bc"]]},{"id":"657c722f.c5c9bc","type":"debug","z":"32266837.fdbe88","name":"estimated actuals timed","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"count","targetType":"msg","x":1510,"y":220,"wires":[]},{"id":"cbb479d8.451368","type":"counter","z":"32266837.fdbe88","name":"Counter","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":1260,"y":280,"wires":[["29137b10.8d3bd4"]]},{"id":"29137b10.8d3bd4","type":"debug","z":"32266837.fdbe88","name":"forecasts timed","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"count","targetType":"msg","x":1540,"y":280,"wires":[]},{"id":"da6427ef.e69458","type":"debug","z":"32266837.fdbe88","name":"total retries","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"count","targetType":"msg","x":850,"y":520,"wires":[]},{"id":"becb3de9.218db","type":"counter","z":"32266837.fdbe88","name":"Counter","init":"0","step":"1","lower":"","upper":"","mode":"increment","outputs":"1","x":680,"y":520,"wires":[["da6427ef.e69458"]]},{"id":"26296625.2bcada","type":"link in","z":"32266837.fdbe88","name":"from timer estimates","links":["d2a66d94.cdde6"],"x":115,"y":360,"wires":[["21b9fd1e.1b65b2"]]},{"id":"fd68fcd0.4f817","type":"link in","z":"32266837.fdbe88","name":"from timer forecasts","links":["b2c4ddba.9457d"],"x":115,"y":460,"wires":[["21b9fd1e.1b65b2"]]},{"id":"e07787.cd769878","type":"influxdb","z":"","hostname":"192.168.10.44","port":"8086","protocol":"http","database":"openWB","name":"openWB","usetls":false,"tls":""},{"id":"8c7609ce.dd5798","type":"position-config","z":"","name":"DACH-1","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":"99","timeZoneDST":"0","stateTimeFormat":"3","stateDateFormat":"12"}]
