# Problem getting data from mysql db to line chart
**URL:** <https://discourse.nodered.org/t/problem-getting-data-from-mysql-db-to-line-chart/67973>\
**Created:** [20 September 2022 12:51 UTC](https://discourse.nodered.org/t/problem-getting-data-from-mysql-db-to-line-chart/67973 "2022-09-20T12:51:28Z")\
**Post date:** [20 September 2022 13:01 UTC](https://discourse.nodered.org/t/problem-getting-data-from-mysql-db-to-line-chart/67973/2 "2022-09-20T13:01:08Z")
You could probably adapt this dynamic routine with little ease...
> [@Dynamic series identification from message, send data to Chart](https://discourse.nodered.org/t/dynamic-series-identification-from-message-send-data-to-chart/36682/5):
> So, i am not 100% certain what you are after but if (by the title "dynamic series") you mean sending alternative types of data from a database (i.e. varying fields and varying quantities) then this should get you close. It was a simple adaption of the previous solution I pointed you to, modified to build the series from the field names of the 1st data element in the data passed in. There are 2 injects to simulate two different sets of mySQL data [image] [{"id":"227e8b13.87c804…
_[View the full topic](https://discourse.nodered.org/t/problem-getting-data-from-mysql-db-to-line-chart/67973)._
