# Problem to var require = global.get('require'); - 3 scheet to 1 xlsx
**URL:** <https://discourse.nodered.org/t/problem-to-var-require-global-get-require-3-scheet-to-1-xlsx/98195>\
**Tags:** function-node\
**Created:** [18 July 2025 07:29 UTC](https://discourse.nodered.org/t/problem-to-var-require-global-get-require-3-scheet-to-1-xlsx/98195 "2025-07-18T07:29:30Z")\
**Post date:** [18 July 2025 08:05 UTC](https://discourse.nodered.org/t/problem-to-var-require-global-get-require-3-scheet-to-1-xlsx/98195/2 "2025-07-18T08:05:53Z")
Hi, firstly your flow was not correctly formatted for the forum so I corrected it for you
````auto
   code goes here
Next, I moved this thread to #General since you are not #Developing Nodes
Lastly, `require` is NOT really recommended or even necessary. I would use the `Setup` tab and add your npm module in there. See the below article for how to:
> **[Use any npm module in Node-RED • FlowFuse](https://flowfuse.com/blog/2023/06/import-modules/)**
> Node-RED has an incredibly rich resource of integrations available, but sometimes you need that little extra. This shows you how.
_[View the full topic](https://discourse.nodered.org/t/problem-to-var-require-global-get-require-3-scheet-to-1-xlsx/98195)._
