# Problems with MQTT flow after Excel import and msg modifications
**URL:** <https://discourse.nodered.org/t/problems-with-mqtt-flow-after-excel-import-and-msg-modifications/78030>\
**Created:** [29 April 2023 10:17 UTC](https://discourse.nodered.org/t/problems-with-mqtt-flow-after-excel-import-and-msg-modifications/78030 "2023-04-29T10:17:30Z")\
**Post date:** [29 April 2023 10:50 UTC](https://discourse.nodered.org/t/problems-with-mqtt-flow-after-excel-import-and-msg-modifications/78030/2 "2023-04-29T10:50:20Z")
I suspect it is one of the JSONata expressions, as explained in your OG thread you may need to force an array
> [@How to create payloads (strings merged/concatenated from array objects) from Excel data?](https://discourse.nodered.org/t/how-to-create-payloads-strings-merged-concatenated-from-array-objects-from-excel-data/68050/14):
> Unless only one is returned. To force that to an array, [$keys()] would `force a single result to a single array, it would not affect a array with multiple values.
Please supply the data going into `change key and ip` functions so i can test.
_[View the full topic](https://discourse.nodered.org/t/problems-with-mqtt-flow-after-excel-import-and-msg-modifications/78030)._
