Problems with node contrib-shelly
This is the basic on/off control flow. Note that I've tweak the location in the CRON+ node. Also, I use the root MQTT topic shellies for the Shelly devices - not sure if that is the default. The 2 MQTT in nodes "Rmt n, Btn b:2" are indirect outputs via my RFXtrx433 dongle listening to LightwaveRF remotes. The mini-flow bottom-right simply refactors the on/off setting to a different MQTT topic structure.
[{"id":"dc1d9eacf2527970","type":"group","z":"7274c13e.dddcc","name":"Office (06/B2) \\n ","style":{"label":true,"fill":"#e3f3d3","color":"#000000"},"nodes":["fa6f876be8fdb6ed","27acead8afccfada","52cf4fc101f69e12","0cbb04eb84b4e172","9995a98b7e38bd7e","3378b7e43506acd0","de29a08ac7cdfa75","7f72e7db2f02151f","0677407524d79180","cc0b3e58f538a8f5","9f18b536c0d9ab96","0d6303b5e5c2df2c","c14d12667bd8f15b","c2e1e806f6862828"],"x":594,"y":203,"w":662,"h":358},{"id":"fa6f876be8fdb6ed","type":"mqtt in","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"","topic":"shellies/shelly_rgbw2_01/color/0/command","qos":"2","datatype":"auto-detect","broker":"3784c9f0.57bab6","nl":false,"rap":true,"rh":0,"inputs":0,"x":945,"y":520,"wires":[["27acead8afccfada"]],"l":false},{"id":"27acead8afccfada","type":"change","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"on","fromt":"str","to":"1","tot":"num"},{"t":"change","p":"payload","pt":"msg","from":"off","fromt":"str","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1005,"y":520,"wires":[["52cf4fc101f69e12"]],"l":false},{"id":"52cf4fc101f69e12","type":"mqtt out","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"environment/light/...","topic":"environment/light/Office/switch","qos":"","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"3784c9f0.57bab6","x":1140,"y":520,"wires":[]},{"id":"0cbb04eb84b4e172","type":"mqtt in","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Rmt 2, Btn b:2","topic":"RFX/known/LIGHTWAVERF-0xF30F69/switches/6","qos":"2","datatype":"auto","broker":"3784c9f0.57bab6","nl":false,"rap":true,"rh":0,"inputs":0,"x":710,"y":400,"wires":[["3378b7e43506acd0"]]},{"id":"9995a98b7e38bd7e","type":"mqtt in","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Rmt 3, Btn b:2","topic":"RFX/known/LIGHTWAVERF-0xF55E26/switches/6","qos":"2","datatype":"auto","broker":"3784c9f0.57bab6","nl":false,"rap":true,"rh":0,"inputs":0,"x":710,"y":440,"wires":[["3378b7e43506acd0"]]},{"id":"3378b7e43506acd0","type":"change","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$lowercase(payload)\t","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"shellies/shelly_rgbw2_01/color/0/command","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":935,"y":420,"wires":[["0d6303b5e5c2df2c"]],"l":false},{"id":"de29a08ac7cdfa75","type":"mqtt in","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Plug State","topic":"shellies/shelly_rgbw2_01/color/0","qos":"2","datatype":"auto","broker":"3784c9f0.57bab6","nl":false,"rap":true,"rh":0,"inputs":0,"x":700,"y":520,"wires":[["7f72e7db2f02151f"]]},{"id":"7f72e7db2f02151f","type":"change","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"","rules":[{"t":"set","p":"#:(file)::lights.ShellyRGB01.state","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":795,"y":520,"wires":[["0677407524d79180"]],"l":false},{"id":"0677407524d79180","type":"debug","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"","active":false,"tosidebar":true,"console":false,"tostatus":true,"complete":"true","targetType":"full","statusVal":"payload","statusType":"msg","x":855,"y":520,"wires":[],"l":false},{"id":"cc0b3e58f538a8f5","type":"cronplus","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Shelly RGB - Solar on, time off","outputField":"payload","timeZone":"","storeName":"file","commandResponseMsgOutput":"output2","defaultLocation":"","defaultLocationType":"default","outputs":2,"options":[{"name":"PM On","topic":"shellies/shelly_rgbw2_01/color/0/command","payloadType":"str","payload":"on","expressionType":"solar","expression":"0 30 15 * * * *","location":"53, -1","offset":"0","solarType":"selected","solarEvents":"eveningGoldenHourStart","lunarType":"all","lunarEvents":"rise,set"},{"name":"PM Off","topic":"shellies/shelly_rgbw2_01/color/0/command","payloadType":"str","payload":"off","expressionType":"cron","expression":"0 0 0 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset","lunarType":"all","lunarEvents":"rise,set"}],"x":770,"y":340,"wires":[["0d6303b5e5c2df2c"],["9f18b536c0d9ab96"]]},{"id":"9f18b536c0d9ab96","type":"debug","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":935,"y":360,"wires":[],"l":false},{"id":"0d6303b5e5c2df2c","type":"link out","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Switch01 out to mqtt local (retained)","links":["cf6709e6.95a6e8"],"x":1095,"y":260,"wires":[]},{"id":"c14d12667bd8f15b","type":"inject","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Shelly RGB On","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"shellies/shelly_rgbw2_01/color/0/command","payload":"on","payloadType":"str","x":740,"y":260,"wires":[["0d6303b5e5c2df2c"]]},{"id":"c2e1e806f6862828","type":"inject","z":"7274c13e.dddcc","g":"dc1d9eacf2527970","name":"Shelly RGB Off","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"shellies/shelly_rgbw2_01/color/0/command","payload":"off","payloadType":"str","x":740,"y":300,"wires":[["0d6303b5e5c2df2c"]]},{"id":"3784c9f0.57bab6","type":"mqtt-broker","name":"nrmain-local (v5)","broker":"localhost","port":"1883","clientid":"nrmain-local","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"5","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"services/nrmain","birthQos":"0","birthRetain":"true","birthPayload":"Online","birthMsg":{},"closeTopic":"services/nrmain","closeQos":"0","closeRetain":"true","closePayload":"Offline","closeMsg":{},"willTopic":"services/nrmain","willQos":"0","willRetain":"true","willPayload":"Offline","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"4e307483d3659ff2","type":"global-config","env":[],"modules":{"node-red-contrib-cron-plus":"3.0.0"}}]
Here is the Dashboard flow that was my prototype - remember, this is D1 not the newer FlowFuse D2.
This is just the Office part of that flow:
[{"id":"2a0a6741d8dae665","type":"group","z":"7274c13e.dddcc","g":"4e1b6aa6d69a735d","name":"Office","style":{"label":true},"nodes":["38dd47468de7d8ae","bcbd6a47e40bc20f","d9dd6d819c79bba1","b5703adf0e0fc901","b07d003b3b4098d9","ac5992d343edff96","570909da18b39da9","bde3fad7168473b0","74a28cd5acc01032","97d835e2c5e26269","386f0e44dfc36b1c","75fd4083c38410d2","07df8f3b4b8b5119"],"x":588,"y":3139,"w":582,"h":202},{"id":"38dd47468de7d8ae","type":"ui_switch","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","label":"Shelly RGB (B:2)","tooltip":"Shelly RGB (Office)","group":"7dcffc5514ad8145","order":1,"width":0,"height":0,"passthru":false,"decouple":"true","topic":"topic","topicType":"msg","style":"","onvalue":"on","onvalueType":"str","onicon":"","oncolor":"","offvalue":"off","offvalueType":"str","officon":"","offcolor":"","animate":false,"className":"","x":1004,"y":3180,"wires":[["d9dd6d819c79bba1"]]},{"id":"bcbd6a47e40bc20f","type":"mqtt in","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"Shelly RGB State","topic":"shellies/shelly_rgbw2_01/color/0","qos":"2","datatype":"auto","broker":"3784c9f0.57bab6","nl":false,"rap":true,"rh":0,"inputs":0,"x":694,"y":3180,"wires":[["38dd47468de7d8ae"]]},{"id":"d9dd6d819c79bba1","type":"mqtt out","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","topic":"shellies/shelly_rgbw2_01/color/0/command","qos":"0","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"3784c9f0.57bab6","x":1129,"y":3180,"wires":[],"l":false},{"id":"b5703adf0e0fc901","type":"mqtt in","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"Shelly RGB Status","topic":"shellies/shelly_rgbw2_01/color/0/status","qos":"2","datatype":"auto","broker":"3784c9f0.57bab6","nl":false,"rap":true,"rh":0,"inputs":0,"x":704,"y":3240,"wires":[["ac5992d343edff96"]]},{"id":"b07d003b3b4098d9","type":"change","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"\"rgb(\" & payload.red & \",\" & payload.green & \",\" & payload.blue & \")\"","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":889,"y":3240,"wires":[["07df8f3b4b8b5119"]],"l":false},{"id":"ac5992d343edff96","type":"json","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","property":"payload","action":"","pretty":false,"x":829,"y":3240,"wires":[["b07d003b3b4098d9","386f0e44dfc36b1c"]],"l":false},{"id":"570909da18b39da9","type":"change","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t    \"red\": payload.r, \t    \"green\": payload.g, \t    \"blue\": payload.b\t}\t","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"shellies/shelly_rgbw2_01/color/0/set","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1069,"y":3240,"wires":[["bde3fad7168473b0"]],"l":false},{"id":"bde3fad7168473b0","type":"mqtt out","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","topic":"shellies/shelly_rgbw2_01/color/0/set","qos":"0","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"3784c9f0.57bab6","x":1129,"y":3240,"wires":[],"l":false},{"id":"74a28cd5acc01032","type":"ui_slider","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","label":"Gain","tooltip":"Bulb 02","group":"7dcffc5514ad8145","order":2,"width":0,"height":0,"passthru":false,"outs":"end","topic":"topic","topicType":"msg","min":0,"max":"255","step":1,"className":"","x":984,"y":3300,"wires":[["75fd4083c38410d2"]]},{"id":"97d835e2c5e26269","type":"mqtt out","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","topic":"","qos":"0","retain":"false","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"3784c9f0.57bab6","x":1129,"y":3300,"wires":[],"l":false},{"id":"386f0e44dfc36b1c","type":"change","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.gain","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":889,"y":3300,"wires":[["74a28cd5acc01032"]],"l":false},{"id":"75fd4083c38410d2","type":"change","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t    \"gain\": payload\t}\t","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"shellies/shelly_rgbw2_01/color/0/set","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1069,"y":3300,"wires":[["97d835e2c5e26269"]],"l":false},{"id":"07df8f3b4b8b5119","type":"ui_colour_picker","z":"7274c13e.dddcc","g":"2a0a6741d8dae665","name":"","label":"Colour","group":"7dcffc5514ad8145","format":"rgb","outformat":"object","showSwatch":true,"showPicker":true,"showValue":true,"showHue":false,"showAlpha":false,"showLightness":true,"square":"false","dynOutput":"false","order":2,"width":0,"height":0,"passthru":false,"topic":"topic","topicType":"msg","className":"","x":984,"y":3240,"wires":[["570909da18b39da9"]]},{"id":"7dcffc5514ad8145","type":"ui_group","name":"Office","tab":"1571ec3755fe98e4","order":5,"disp":true,"width":"6","collapse":false,"className":""},{"id":"3784c9f0.57bab6","type":"mqtt-broker","name":"nrmain-local (v5)","broker":"localhost","port":"1883","clientid":"nrmain-local","autoConnect":true,"usetls":false,"compatmode":false,"protocolVersion":"5","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"services/nrmain","birthQos":"0","birthRetain":"true","birthPayload":"Online","birthMsg":{},"closeTopic":"services/nrmain","closeQos":"0","closeRetain":"true","closePayload":"Offline","closeMsg":{},"willTopic":"services/nrmain","willQos":"0","willRetain":"true","willPayload":"Offline","willMsg":{},"userProps":"","sessionExpiry":""},{"id":"1571ec3755fe98e4","type":"ui_tab","name":"Lighting","icon":"lightbulb_outline","order":1,"disabled":false,"hidden":false},{"id":"fea77fa667b10d22","type":"global-config","env":[],"modules":{"node-red-dashboard":"3.6.6"}}]
This is what it looks like:
As I mentioned, I don't really use either of the Dashboards. Unfortunately, my live home dashboards lighting page is currently due for a facelift and nothing is currently connected, but here is a preview:
Imagine each of the named room cards containing controls for the lighting not dissimilar to the Dashboard example.
Honestly, I so rarely use the lighting page that I've not a lot of incentive to finish it right now, too many other draws on my time. My lighting is entirely automated where it needs to be so very little reason to muck about with a web page. :slightly_smiling_face:
Made my lighting all singing, all dancing, not just switch on/off auto/manual and slight changes of colours/levels to suit mood.
Maybe my mood is always dark and red so I don't need to change the lighting! :grinning_cat:
Acrylangel, the creator of "node-red-dashboard-2-vue-color-wheel" has solved several issues and so it is time to test.
Perhaps this is interesting for other users as well.
