# Pull request proposal: automatic certificate renewal
**URL:** <https://discourse.nodered.org/t/pull-request-proposal-automatic-certificate-renewal/21282>\
**Created:** [4 February 2020 21:26 UTC](https://discourse.nodered.org/t/pull-request-proposal-automatic-certificate-renewal/21282 "2020-02-04T21:26:45Z")\
**Showing post:** 3
**Post date:** [6 February 2020 19:30 UTC](https://discourse.nodered.org/t/pull-request-proposal-automatic-certificate-renewal/21282/3 "2020-02-06T19:30:48Z")
> [@knolleary](#):
> code a user may have added
Hey Nick,
Didn't knew the settings.js file was being used for that kind of purposes.
But indeed that makes sense ...
So when I add this to the settings.js file:
    // The following property can be used to renew credential files at regular time intervals (seconds)
    credentialRenewalTime: 3600,
    // The following property can be used to add a custom function to renew credentials.
    // A keypair (i.e. both the private key and the certificate) need to be returned.
    // In most cases the code from the 'https' property can be re-used here ...
    functionCredentialRenewal: function() {
        return {
            key: fs.readFileSync('privkey.pem'),
            cert: fs.readFileSync('cert.pem')
And I add this to the red.js file:
if (settings.https) {
    server = https.createServer(settings.https,function(req,res) {
        app(req,res);
    // Setup automatic certificate renewal for NodeJs version 11 and above
    if (settings.credentialRenewalTime && settings.functionCredentialRenewal && typeof settings.functionCredentialRenewal === "function") {
        if (server.setSecureContext) {
            console.log("Checking renewed credentials every " + parseInt(settings.credentialRenewalTime) + " seconds.");
            setInterval(function () {
                try {
                    //console.log("Checking for renewed credentials.");
                    var renewedHttps = settings.functionCredentialRenewal();
                    server.setSecureContext(renewedHttps);
                } catch(err) {
                    console.log("Cannot renew the credentials: " + err);
            }, parseInt(settings.credentialRenewalTime) * 1000);
        else {
            console.log("Cannot renew credentials automatically. NodeJs version 11 or above is required.");
} else {
    server = http.createServer(function(req,res) {app(req,res);});
Then it also works ...
It is a pity that the existing '_https_' property isn't a function. Because now you have to specify both file paths (privkey.pem and cert.pem) **twice** in the settings, which you might forget...
Any other things that I need to change?
Bart
_[View the full topic](https://discourse.nodered.org/t/pull-request-proposal-automatic-certificate-renewal/21282)._
