# Questions on node-red-contrib-ui-svg
**URL:** <https://discourse.nodered.org/t/questions-on-node-red-contrib-ui-svg/37031>\
**Created:** [5 December 2020 01:32 UTC](https://discourse.nodered.org/t/questions-on-node-red-contrib-ui-svg/37031 "2020-12-05T01:32:19Z")\
**Showing post:** 9
**Post date:** [6 December 2020 21:47 UTC](https://discourse.nodered.org/t/questions-on-node-red-contrib-ui-svg/37031/9 "2020-12-06T21:47:14Z")
Hi @Sean-McG,
I have implemented some changes on Github (not on NPM yet). This version can be installed when being inside the .node-red folder:
npm install bartbutenaers/node-red-contrib-ui-svg
- A _ **new section** _ about [reset-panzoom-via-msg](https://github.com/bartbutenaers/node-red-contrib-ui-svg#reset-panzoom-via-msg) has been added to the readme page.
- The _ **double click bug** _ should be fixed. That was a tough one to debug 🤢. Note that I have change the behaviour a bit when using a mouse: first doubleclick is zoom-in, second doubleclick is zoom-out, and so on... Previously the behaviour was: zoom in on every double click, and zoom-out on every shift-double click.
- It is indeed possible to _ **manipulate the viewbox** _. Here is a demo that demonstrates how to implement panning/zooming via the viewport (see the viewbox dimensions in the status of the function node!):
_[View the full topic](https://discourse.nodered.org/t/questions-on-node-red-contrib-ui-svg/37031)._
