# Radar graph not scaling to space correctly
**URL:** <https://discourse.nodered.org/t/radar-graph-not-scaling-to-space-correctly/74457>\
**Tags:** node-red-dashboard\
**Created:** [31 January 2023 02:45 UTC](https://discourse.nodered.org/t/radar-graph-not-scaling-to-space-correctly/74457 "2023-01-31T02:45:24Z")\
**Post date:** [31 January 2023 10:30 UTC](https://discourse.nodered.org/t/radar-graph-not-scaling-to-space-correctly/74457/2 "2023-01-31T10:30:11Z")
Why are you both sending `msg` and returning `msg` in your functions?
and why is the radar function sending the line graph then the RadaeGraph?
msg.info = 'LineGraph';
msg.ui_control = ({ look: 'line' });
node.send(msg);
msg.info = 'RadarGraph';
msg.ui_control = ({look: 'radar'});
node.send(msg);
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/radar-graph-not-scaling-to-space-correctly/74457)._
