# Ras Pi supply voltage
**URL:** <https://discourse.nodered.org/t/ras-pi-supply-voltage/8791>\
**Created:** [9 March 2019 22:41 UTC](https://discourse.nodered.org/t/ras-pi-supply-voltage/8791 "2019-03-09T22:41:48Z")\
**Showing post:** 12
**Post date:** [10 March 2019 20:01 UTC](https://discourse.nodered.org/t/ras-pi-supply-voltage/8791/12 "2019-03-10T20:01:58Z")
> [@dceejay](#):
> I think this voltage thing is fairly Pi specific
Seems indeed the **vcgencmd** is Raspberry specifc, and other devices with Broadcom VideoCore processors. So I agree we should put this stuff in a separate node. Read somewhere that **vcgencmd** stands for " **V** ideo **C** ore **gen** eral **c** om **m** an **d**". Should we call it **node-red-contrib-videocom**?
> [@Paul-Reed](#):
> The resulting bit pattern is
How should the output look like: an array of **booleans** in the payload? E.g.
    "payload": {
        "under_voltage_detected" : true,
        "arm_frequency_capped" : true,
        "currently_throttled" : true,
        "soft_temperature_limit_active" : true,
        "under_voltage_occurred" : true,
        "arm_frequency_capped_occurred" : true,
        "throttling_occurred" : true,
        "soft_temperature_limit_occurred" : true
Or should it be separate messages with their own topic? E.g.
    "payload": true,
    "topic": "under_voltage_detected"
> [@Paul-Reed](#):
> but it's easy to get carried away - as deecjay has pointed out.
Indeed ...
_[View the full topic](https://discourse.nodered.org/t/ras-pi-supply-voltage/8791)._
