Raspberry pi outdated software
That's the default, you don't need it.
@TotallyInformation OK :ok_hand:
and for humans it's easier to read without the --json :slight_smile:
As I said sometimes it will only upgrade to a level it is allowed to safely by the semantic versioning - that is the wanted level. There may be a version it knows about but won't upgrade to unless you force it - that is the latest version... they may of course all be the same.
Yes, but easier to process in Node-RED with it :wink: So depends what you want t o
That was the reason for returning json as I was recommending using a node-red flow to send a notification when an update is available. :sunglasses:
@dceejay @TotallyInformation I must say @TotallyInformation , he is right. I need to process that data, so the option --json is very welcome.:slight_smile:
no problem - I thought you had gone away from just updating dashboard to the more general how do I see all the things that can be updated - which is a lot easier to do manually imho.. but hey.
@dceejay :ok_hand:
Just slightly off-topic, but I can't remember the last time I've run npm outdated. Is that going overboard with "if it ain't broke..."? When is it a good idea?
Well, I run it maybe once a month or so along with npm -g outdated. I find it easier than going through the built-in palette manager. I do a general sudo apt update && sudo apt upgrade at the same time.
Personally, I find it easier to keep things reasonably up-to-date than suddenly finding I have loads of updates to wade through at one time. Of course, having rock-solid backups helps as well since it makes recovery easy should something go awry.
Got it. If we're just talking about NR nodes, I'll stick to the palette manager. Updating everything in on the Pi has been a bumpy road at times.
