Reading a Json file from a render farm and display in UI Table
Hi,
I made a small personal Render-Farm that writes and overwrites a Json text file to an ftp every minute. In Node Red I read this text file with a "http request node" that then gets fed into a UI Table. The Table gets filled out correctly. The only issue I have is that the "http request node" doesn't read the latest version of this text file. So the text file updates every min with new data. If I go directly to the http link of the text file with a browser I see the data getting updated every min. But in Node Red the "http request node" doesn't seem to update. Whenever I send a Get it reads the first text file that was made. It's like it doesn't clear the history or something. How does one read a text file on a http link in Node Red?
Below an example of the text file:
{"SHOT":"SHOT_01_HOR_ALL-LAYERS_HANGAR-INTRO","RANGE":"(1..100)","PROG":33,"FRAMES":"<34..100>"},
{"SHOT":"SHOT_02_HOR_ALL-LAYERS_FlY-OVER","RANGE":"(1..110)","PROG":0,"FRAMES":"<1..110>"},
{"SHOT":"SHOT_03_HOR_ALL-LAYERS_STEP-DOWN","RANGE":"(1..55)","PROG":0,"FRAMES":"<1..55>"},
{"SHOT":"SHOT_04_HOR_ALL-LAYERS_DECREASE-TENSION","RANGE":"(1..55)","PROG":0,"FRAMES":"<1..55>"},
{"SHOT":"SHOT_05_HOR_ALL-LAYERS_INCREASE-TENSION","RANGE":"(1..50)","PROG":0,"FRAMES":"<1..50>"},
{"SHOT":"SHOT_06_HOR_ALL-LAYERS_CLOSE-TLS","RANGE":"(1..75)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_07_HOR_ALL-LAYERS_CLOSE-TOECAP","RANGE":"(1..55)","PROG":0,"FRAMES":"<1..55>"},
{"SHOT":"SHOT_08_HOR_ALL-LAYERS_CLOSE-SHOE","RANGE":"(1..40)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_09_HOR_ALL-LAYERS_LACE-CLOSE","RANGE":"(1..60)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_10_HOR_ALL-LAYERS_TLS-WIRE-IN","RANGE":"(1..30)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_11_HOR_ALL-LAYERS_TLS-PUSH-IN","RANGE":"(1..50)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_12_HOR_ALL-LAYERS_TLS-PULL-OUT","RANGE":"(1..20)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_13_HOR_ALL-LAYERS_WIRE-CLOSE-SHOE","RANGE":"(1..40)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_14_HOR_ALL-LAYERS_CONTAINER","RANGE":"(1..100)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_15_HOR_ALL-LAYERS_TLS-MORPHE","RANGE":"(1..125)","PROG":0,"FRAMES":"<1..125>"},
{"SHOT":"SHOT_16_HOR_ALL-LAYERS_AIRPLANE-MORPHE","RANGE":"(1..125)","PROG":0,"FRAMES":"<1..125>"},
{"SHOT":"SHOT_17_HOR_ALL-LAYERS_SIDE-SHOE","RANGE":"(1..40)","PROG":0,"FRAMES":"<1..40>"},
{"SHOT":"SHOT_18_HOR_ALL-LAYERS_SHOE-TURN","RANGE":"(1..85)","PROG":0,"FRAMES":"<1..85>"},
{"SHOT":"SHOT_19_HOR_ALL-LAYERS_LACE-CLOSE-INSERT","RANGE":"(1..55)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_20_HOR_ALL-LAYERS_INSERT-END","RANGE":"(1..60)","PROG":0,"FRAMES":"<1..60>"},
{"SHOT":"SHOT_21_HOR_ALL-LAYERS_MICROFIBER","RANGE":"(1..60)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_22_HOR_ALL-LAYERS_DECREASE-TENSION-B","RANGE":"(1..55)","PROG":0,"FRAMES":"<1..55>"},
{"SHOT":"SHOT_23_HOR_ALL-LAYERS_PRINT-A","RANGE":"(1..4)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_24_HOR_ALL-LAYERS_PRINT-B","RANGE":"(1..4)","PROG":100,"FRAMES":"< COMPLETE >"},
{"SHOT":"SHOT_25_HOR_ALL-LAYERS_FlY-OVER-NO-SHOES","RANGE":"(110..110)","PROG":100,"FRAMES":"< COMPLETE >"}
