Tell me the highest
,nncount number that works.
To make this easier - use this flow:
the highest ,nn count number worked for me is 50
rest i tried the example flow you send for testing the highest count number upto 100 but didnot worked
Tell me the highest
Did you run the demo flow to assess this?
show me a screenshot
yes didnot worked for that
Did you press the "read next address" until it got down to 50?
show me a screen shot.
please dont take any short cuts - please do as I ask.
@Steve-Mcl
i tried it all way but i get the data when it come to 62
ok, that fine.
now try this flow
[{"id":"ee548f43b60a3cfb","type":"inject","z":"99321f37fd961305","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["3fc9a582ec030e99"]]},{"id":"17483553facc8081","type":"debug","z":"99321f37fd961305","name":"part 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":140,"wires":[]},{"id":"151485cfc8585f0a","type":"buffer-parser","z":"99321f37fd961305","name":"Convert array to named values","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16le","name":"extrusionRodNumber","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"extrusionTime","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"temperatureGiven","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"temperatureSetting","offset":6,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"rapida","offset":28,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"chamdaDe","offset":30,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"protecaob","offset":32,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"protecaoa","offset":34,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"freagem","offset":36,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"limitPressureOfMasterCylinder","offset":42,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"veloc4","offset":44,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"veloc3","offset":46,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"veloc2","offset":48,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"rapida","offset":50,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"fillingPressureGiven","offset":52,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"slopeGivenOfBreakthroughPressure","offset":54,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"velocityAttenuationRatio","offset":58,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"velocityAttenuationStroke","offset":60,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"maximumStrokeGiven","offset":68,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"swap16","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload1","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":710,"y":140,"wires":[["17483553facc8081","a3c6cd2ccde899bf"]]},{"id":"3fc9a582ec030e99","type":"change","z":"99321f37fd961305","name":"D990,50","rules":[{"t":"set","p":"topic","pt":"msg","to":"D990,50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":140,"wires":[["a1057e4a80c0d287"]]},{"id":"a1057e4a80c0d287","type":"link call","z":"99321f37fd961305","name":"","links":["eaccb1754fe661ae"],"linkType":"static","timeout":"30","x":440,"y":140,"wires":[["151485cfc8585f0a","eef6eca7504c7085"]]},{"id":"ce9c462e93a1e8d3","type":"buffer-parser","z":"99321f37fd961305","name":"Convert array to named values","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16le","name":"actualValueOfCoil","offset":36,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"breakthroughPressure","offset":60,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"residualPosition","offset":72,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"masterCylinderPosition","offset":74,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"rateOfDecay","offset":76,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"pressureOfMainCylinder","offset":82,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"speedGiven","offset":84,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"settingPointOfCoil","offset":86,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"pressureOfSideCylinder","offset":88,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"coilCurrent","offset":90,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"masterCylinderSpeed","offset":92,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"swap16","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":710,"y":260,"wires":[["dd70bbf1fcc54974","e1898eb76bbd3abe"]]},{"id":"a3c6cd2ccde899bf","type":"change","z":"99321f37fd961305","name":"D1040,50","rules":[{"t":"set","p":"topic","pt":"msg","to":"D1040,50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":260,"wires":[["bdbcd691d033c3d1"]]},{"id":"bdbcd691d033c3d1","type":"link call","z":"99321f37fd961305","name":"","links":["eaccb1754fe661ae"],"linkType":"static","timeout":"30","x":440,"y":260,"wires":[["7f04a5965542d46f","ce9c462e93a1e8d3"]]},{"id":"eef6eca7504c7085","type":"debug","z":"99321f37fd961305","name":"PLC Data 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":100,"wires":[]},{"id":"7f04a5965542d46f","type":"debug","z":"99321f37fd961305","name":"PLC Data 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":220,"wires":[]},{"id":"dd70bbf1fcc54974","type":"debug","z":"99321f37fd961305","name":"part 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":260,"wires":[]},{"id":"e1898eb76bbd3abe","type":"function","z":"99321f37fd961305","name":"merge payload1 & payload2","func":"msg.payload = {\n ... msg.payload1,\n ... msg.payload2\n}\ndelete msg.payload1\ndelete msg.payload2\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":450,"y":340,"wires":[["dd3a59aded3ed544"]]},{"id":"dd3a59aded3ed544","type":"debug","z":"99321f37fd961305","name":"final result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":340,"wires":[]},{"id":"16dbc1e8e4c7b0f1","type":"group","z":"99321f37fd961305","name":"Read PLC Subroutine","style":{"label":true},"nodes":["38e76ddd4c78d4d9","eaccb1754fe661ae","3cc8f41d3137cbf6","f7fbc71a773c84f4","395888bce11d8592"],"x":84,"y":439,"w":492,"h":142},{"id":"38e76ddd4c78d4d9","type":"MC Read","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":260,"y":480,"wires":[["3cc8f41d3137cbf6"]]},{"id":"eaccb1754fe661ae","type":"link in","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"Read PLC Subroutine","links":[],"x":125,"y":480,"wires":[["38e76ddd4c78d4d9"]]},{"id":"3cc8f41d3137cbf6","type":"link out","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"return","mode":"return","links":[],"x":405,"y":480,"wires":[]},{"id":"f7fbc71a773c84f4","type":"catch","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"","scope":"group","uncaught":false,"x":270,"y":540,"wires":[["395888bce11d8592"]]},{"id":"395888bce11d8592","type":"debug","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"Read Error","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":460,"y":540,"wires":[]},{"id":"8c926f873226d344","type":"MC Protocol Connection","name":"","host":"192.168.2.20","port":"5001","protocol":"TCP","frame":"1E","plcType":"Q","ascii":false,"PLCStation":"2","PCStation":"255","PLCModuleNo":"2","network":"2","octalInputOutput":false,"timeout":"1000"}]
show me what you get
@Steve-Mcl
I got it but the thing is would i need to sort the address list
first screenshot
for debug PLC data 1
for debug part 1
for rest
Good, so now you have 100 data items read in 2 chunks, all nicely assembled into a singe object.
Now if you want X, Y and M values, tell me what they are in a list like this...
| Address | Name |
| Y4 | powerOn |
| Y5 | machineReady |
| Y9 | inCycle |
| M22 | overCycle |
| etc | etc |
| etc | etc |
| etc | etc |
| OUT | OUTPUT NAME | ADDRESS | TAG |
| Y0 | SOL PUMP COMBINATION | Y | 0 |
| Y1 | CONSTANT SPEED | Y | 1 |
| Y2 | CONTAINER FORWARD OIL RETURN | Y | 2 |
| Y3 | CONTAINER BACKWARD OIL RETURN | Y | 3 |
| Y4 | SEMI AUTO MODE | Y | 4 |
| Y5 | BACK UP | Y | 5 |
| Y6 | OUT KNOCKER UP | Y | 6 |
| Y7 | OUT KNOCKER DOWN | Y | 7 |
| Y10 | MAIN RAM PRESSURE RELIEF VALUE | Y | 10 |
| Y11 | CONTAINER HEATING | Y | 11 |
| Y12 | NO LOAD ELETRICAL CURRENT | Y | 12 |
| Y13 | SPEED 1 ADJUSTMENT CURRENT | Y | 13 |
| Y14 | SPEED 2 ADJUSTMENT CURRENT | Y | 14 |
| Y15 | SPEED 3 ADJUSTMENT CURRENT | Y | 15 |
| Y16 | SPEED 4 ADJUSMENT CURRENT | Y | 16 |
| Y17 | SPEED 5 ADJUSTMENTCURRENT | Y | 17 |
| Y20 | MAIN RAM FORWARD | Y | 20 |
| Y21 | MAIN RAM BACKWARD | Y | 21 |
| Y22 | CONTAINER FORWAD | Y | 22 |
| Y23 | CONATINER BACKWARD | Y | 23 |
| Y24 | SHEAR DOWN | Y | 24 |
| Y25 | SHEAE UP | Y | 25 |
| Y26 | OIL COMBINATION | Y | 26 |
| Y27 | SURGE VALVE OPEN | Y | 27 |
| Y30 | BILLET LOADER FORWARD | Y | 30 |
| Y31 | BILLET LOADER BACKWARD | Y | 31 |
| Y32 | PULLAR START | Y | 32 |
| Y33 | PULLER STOP | Y | 33 |
| Y34 | DIE SLIDE IN | Y | 34 |
| Y35 | DIE SLIDE OUT | Y | 35 |
| Y36 | BILLET PUSHING CYLINDER FORWARD | Y | 36 |
| Y37 | BILLET PUSHING CYLINDER BACKWARD | Y | 37 |
| Y40 | PISTON PUMP OVERFLOW VALVE 1 | Y | 40 |
| Y41 | PISTON PUMP OVERFLOW VALVE 2 | Y | 41 |
| Y42 | VANE PUMP OVERFLOW VALVE 1 | Y | 42 |
| Y43 | VANE PUMP OVERFLOW VALVE 2 | Y | 43 |
| Y44 | SURGE VALVE CLOSE | Y | 44 |
| Y45 | 120L pump overfllow valve | Y | 45 |
| Y46 | piston pump overflow valve 3# | Y | 46 |
| Y47 | 1# motor on | Y | 47 |
| Y50 | 1# motor on | Y | 50 |
| Y51 | 1# motor on | Y | 51 |
| Y52 | 2# motor on | Y | 52 |
| Y53 | 2# motor on | Y | 53 |
| Y54 | 2# motor on | Y | 54 |
| Y55 | 3# motor on | Y | 55 |
| Y56 | 3# motor on | Y | 56 |
| Y57 | 3# motor on | Y | 57 |
| Y60 | back up | Y | 60 |
| Y61 | constant speed | Y | 61 |
| Y62 | air cylinder forward | Y | 62 |
| Y63 | shear up | Y | 63 |
| Y64 | vane pump overflow valve 3# | Y | 64 |
| Y65 | piston pump overflow valve 4# | Y | 65 |
| Y66 | cooling pump on | Y | 66 |
| Y67 | die slide forward | Y | 67 |
| Y70 | die slide backward | Y | 70 |
| Y71 | container sealing 1 | Y | 71 |
| Y72 | container sealing 2 | Y | 72 |
| Y73 | stem out | Y | 73 |
| Y74 | stem in | Y | 74 |
| Y75 | billet pushing forward | Y | 75 |
| Y76 | billet pushing backward | Y | 76 |
| Y77 | stem lock-up | Y | 77 |
| Y100 | oil combination | Y | 100 |
| Y101 | container sealing on | Y | 101 |
| Y102 | main ram backward oil return | Y | 102 |
| Y103 | billet loader enable | Y | 103 |
| Y104 | forward inching | Y | 104 |
| Y105 | backward inching | Y | 105 |
| Y106 | high speed inching | Y | 106 |
| Y107 | billet loader searching home position | Y | 107 |
| Y110 | position of billet loader backward | Y | 110 |
| Y111 | position of billet loader forward | Y | 111 |
| Y112 | pistion 3 | Y | 112 |
| Y113 | billet loader reaching home position | Y | 113 |
| Y114 | power of billet loader | Y | 114 |
| Y115 | back up | Y | 115 |
| Y116 | back up | Y | 116 |
| Y117 | container heating2 | Y | 117 |
this are output y addresses
Run this flow:
[{"id":"5cf897a3fbea442e","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":620,"y":1240,"wires":[["79bcbec04a949f2e"]]},{"id":"660df0a113c4dae3","type":"inject","z":"99321f37fd961305","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Y0,120","x":450,"y":1240,"wires":[["5cf897a3fbea442e"]]},{"id":"79bcbec04a949f2e","type":"debug","z":"99321f37fd961305","name":"PLC Data 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":1240,"wires":[]},{"id":"7be52be29e860b1f","type":"inject","z":"99321f37fd961305","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"K2Y0,16","x":460,"y":1300,"wires":[["0d15654de772c499"]]},{"id":"0d15654de772c499","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":620,"y":1300,"wires":[["306c7cf39ba72617"]]},{"id":"306c7cf39ba72617","type":"debug","z":"99321f37fd961305","name":"PLC Data 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":1300,"wires":[]},{"id":"f449e2485b31eef4","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":620,"y":1360,"wires":[["f1235dab7ede68cc"]]},{"id":"9de73af43582dd80","type":"inject","z":"99321f37fd961305","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"K4Y0,8","x":450,"y":1360,"wires":[["f449e2485b31eef4"]]},{"id":"f1235dab7ede68cc","type":"debug","z":"99321f37fd961305","name":"PLC Data 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":1360,"wires":[]},{"id":"8c926f873226d344","type":"MC Protocol Connection","name":"","host":"192.168.2.20","port":"5001","protocol":"TCP","frame":"1E","plcType":"Q","ascii":false,"PLCStation":"2","PCStation":"255","PLCModuleNo":"2","network":"2","octalInputOutput":false,"timeout":"1000"}]
Show me all three payloads
@Steve-Mcl
before that D990 and D1040 with final output in debug
{"extrusionRodNumber":0,"extrusionTime":2,"temperatureGiven":420,"temperatureSetting":195,"rapida":400,"chamdaDe":4000,"protecaob":3000,"protecaoa":2000,"freagem":1000,"limitPressureOfMasterCylinder":280,"veloc4":400,"veloc3":400,"veloc2":400,"fillingPressureGiven":100,"slopeGivenOfBreakthroughPressure":10,"velocityAttenuationRatio":0,"velocityAttenuationStroke":0,"maximumStrokeGiven":15653,"actualValueOfCoil":0,"breakthroughPressure":0,"residualPosition":12303,"masterCylinderPosition":3350,"rateOfDecay":0,"pressureOfMainCylinder":0,"speedGiven":0,"settingPointOfCoil":204,"pressureOfSideCylinder":0,"coilCurrent":0,"masterCylinderSpeed":0}
it does not consist 100 tag addresses from both tag
Run this flow:
[{"id":"5cf897a3fbea442e","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":620,"y":1240,"wires":[["79bcbec04a949f2e"]]},{"id":"660df0a113c4dae3","type":"inject","z":"99321f37fd961305","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Y0,120","x":450,"y":1240,"wires":[["5cf897a3fbea442e"]]},{"id":"79bcbec04a949f2e","type":"debug","z":"99321f37fd961305","name":"PLC Data 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":1240,"wires":[]},{"id":"7be52be29e860b1f","type":"inject","z":"99321f37fd961305","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"K2Y0,16","x":460,"y":1300,"wires":[["0d15654de772c499"]]},{"id":"0d15654de772c499","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":620,"y":1300,"wires":[["306c7cf39ba72617"]]},{"id":"306c7cf39ba72617","type":"debug","z":"99321f37fd961305","name":"PLC Data 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":1300,"wires":[]},{"id":"f449e2485b31eef4","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":620,"y":1360,"wires":[["f1235dab7ede68cc"]]},{"id":"9de73af43582dd80","type":"inject","z":"99321f37fd961305","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"K4Y0,8","x":450,"y":1360,"wires":[["f449e2485b31eef4"]]},{"id":"f1235dab7ede68cc","type":"debug","z":"99321f37fd961305","name":"PLC Data 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":1360,"wires":[]},{"id":"8c926f873226d344","type":"MC Protocol Connection","name":"","host":"192.168.2.20","port":"5001","protocol":"TCP","frame":"1E","plcType":"Q","ascii":false,"PLCStation":"2","PCStation":"255","PLCModuleNo":"2","network":"2","octalInputOutput":false,"timeout":"1000"}]Show me all three payloads
No, it contains the items specified in the Buffer Parser.
If you WANT 100 items, you will have to include them in the Buffer Parser like I did.
I did a selection for demonstration purposes.
I cannot do everything for you. I have given you the knowledge, you will have to do some things yourself.
Now try this flow - show me the output of final Result (expand all parts)
[{"id":"ee548f43b60a3cfb","type":"inject","z":"99321f37fd961305","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":140,"wires":[["3fc9a582ec030e99"]]},{"id":"17483553facc8081","type":"debug","z":"99321f37fd961305","name":"part 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":140,"wires":[]},{"id":"151485cfc8585f0a","type":"buffer-parser","z":"99321f37fd961305","name":"Convert array to named values","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16le","name":"extrusionRodNumber","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"extrusionTime","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"temperatureGiven","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"temperatureSetting","offset":6,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"rapida","offset":28,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"chamdaDe","offset":30,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"protecaob","offset":32,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"protecaoa","offset":34,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"freagem","offset":36,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"limitPressureOfMasterCylinder","offset":42,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"veloc4","offset":44,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"veloc3","offset":46,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"veloc2","offset":48,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"rapida","offset":50,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"fillingPressureGiven","offset":52,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"slopeGivenOfBreakthroughPressure","offset":54,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"velocityAttenuationRatio","offset":58,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"velocityAttenuationStroke","offset":60,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"maximumStrokeGiven","offset":68,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"swap16","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload1","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":710,"y":140,"wires":[["17483553facc8081","a3c6cd2ccde899bf"]]},{"id":"3fc9a582ec030e99","type":"change","z":"99321f37fd961305","name":"D990,50","rules":[{"t":"set","p":"topic","pt":"msg","to":"D990,50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":140,"wires":[["a1057e4a80c0d287"]]},{"id":"a1057e4a80c0d287","type":"link call","z":"99321f37fd961305","name":"","links":["eaccb1754fe661ae"],"linkType":"static","timeout":"30","x":440,"y":140,"wires":[["151485cfc8585f0a","eef6eca7504c7085"]]},{"id":"ce9c462e93a1e8d3","type":"buffer-parser","z":"99321f37fd961305","name":"Convert array to named values","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16le","name":"actualValueOfCoil","offset":36,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"breakthroughPressure","offset":60,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"residualPosition","offset":72,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"masterCylinderPosition","offset":74,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"rateOfDecay","offset":76,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"pressureOfMainCylinder","offset":82,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"speedGiven","offset":84,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"settingPointOfCoil","offset":86,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"pressureOfSideCylinder","offset":88,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"coilCurrent","offset":90,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"masterCylinderSpeed","offset":92,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"swap16","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"return","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":710,"y":260,"wires":[["dd70bbf1fcc54974","fc265c85f748fb8d"]]},{"id":"a3c6cd2ccde899bf","type":"change","z":"99321f37fd961305","name":"D1040,50","rules":[{"t":"set","p":"topic","pt":"msg","to":"D1040,50","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":260,"wires":[["bdbcd691d033c3d1"]]},{"id":"bdbcd691d033c3d1","type":"link call","z":"99321f37fd961305","name":"","links":["eaccb1754fe661ae"],"linkType":"static","timeout":"30","x":440,"y":260,"wires":[["7f04a5965542d46f","ce9c462e93a1e8d3"]]},{"id":"eef6eca7504c7085","type":"debug","z":"99321f37fd961305","name":"PLC Data 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":100,"wires":[]},{"id":"7f04a5965542d46f","type":"debug","z":"99321f37fd961305","name":"PLC Data 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":650,"y":220,"wires":[]},{"id":"dd70bbf1fcc54974","type":"debug","z":"99321f37fd961305","name":"part 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":990,"y":260,"wires":[]},{"id":"e1898eb76bbd3abe","type":"function","z":"99321f37fd961305","name":"merge payloads","func":"msg.payload = {\n ... msg.payload1,\n ... msg.payload2,\n Y: {\n ...msg.payload3\n }\n}\ndelete msg.payload1\ndelete msg.payload2\ndelete msg.payload3\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":420,"wires":[["dd3a59aded3ed544"]]},{"id":"dd3a59aded3ed544","type":"debug","z":"99321f37fd961305","name":"final result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1010,"y":420,"wires":[]},{"id":"fc265c85f748fb8d","type":"change","z":"99321f37fd961305","name":"K4Y0,120","rules":[{"t":"set","p":"topic","pt":"msg","to":"Y0,120","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":340,"wires":[["bafe2d392b393fdb"]]},{"id":"bafe2d392b393fdb","type":"MC Read","z":"99321f37fd961305","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"0","errorHandling":"throw","outputs":1,"x":420,"y":340,"wires":[["4c29f73c76822417"]]},{"id":"4c29f73c76822417","type":"change","z":"99321f37fd961305","name":"set payload3","rules":[{"t":"move","p":"payload","pt":"msg","to":"payload3","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":340,"wires":[["e1898eb76bbd3abe"]]},{"id":"16dbc1e8e4c7b0f1","type":"group","z":"99321f37fd961305","name":"Read PLC Subroutine","style":{"label":true},"nodes":["38e76ddd4c78d4d9","eaccb1754fe661ae","3cc8f41d3137cbf6","f7fbc71a773c84f4","395888bce11d8592"],"x":64,"y":499,"w":492,"h":142},{"id":"38e76ddd4c78d4d9","type":"MC Read","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"","topic":"","connection":"8c926f873226d344","address":"topic","addressType":"msg","outputFormat":"1","errorHandling":"throw","outputs":1,"x":240,"y":540,"wires":[["3cc8f41d3137cbf6"]]},{"id":"eaccb1754fe661ae","type":"link in","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"Read PLC Subroutine","links":[],"x":105,"y":540,"wires":[["38e76ddd4c78d4d9"]]},{"id":"3cc8f41d3137cbf6","type":"link out","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"return","mode":"return","links":[],"x":385,"y":540,"wires":[]},{"id":"f7fbc71a773c84f4","type":"catch","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"","scope":"group","uncaught":false,"x":250,"y":600,"wires":[["395888bce11d8592"]]},{"id":"395888bce11d8592","type":"debug","z":"99321f37fd961305","g":"16dbc1e8e4c7b0f1","name":"Read Error","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":440,"y":600,"wires":[]},{"id":"8c926f873226d344","type":"MC Protocol Connection","name":"","host":"192.168.2.20","port":"5001","protocol":"TCP","frame":"1E","plcType":"Q","ascii":false,"PLCStation":"2","PCStation":"255","PLCModuleNo":"2","network":"2","octalInputOutput":false,"timeout":"1000"}]
Yes i know that you helped me a lot with a real example thank you for that no doubt the other thing i have to do.
But
@Steve-Mcl
i need to know that how to find bytes offset and index offset
Do you know what a 16 bit value is?
Do you know what a BYTE is?
1 MC READ value is 16 bit AKA 2 bytes.
therefore:
[xxxx, yyyy, zzzz] then xxxx is bytes 0 & 1, yyyy is bytes 2 & 3, and so on.It is simple maths.
Byte Offset = (Address - Start Address) * 2
e.g.
Address: D1048
Start Address: D1040
Byte Offset = (1048 - 1040) * 2 = 16
Read this again:
You might have missed this post ↑
I am going to leave you to do this by yourself now.
I have spent over 4 hours of my own personal time, across the last few days helping you - I think that is enough.
I have given you a LOT of demos, a LOT of information and enough tips and hints to put this all together by yourself.
Best of luck. Steve.
Add a BOOL as i have explained twice already
Here is it one last time.
Calculate the offset to the DM, enter the BIT number, give it a name
