# ReferenceError: node is not defined
**URL:** https://discourse.nodered.org/t/referenceerror-node-is-not-defined/8523
**Category:** General
**Created:** [2 March 2019 09:17 UTC](https://discourse.nodered.org/t/referenceerror-node-is-not-defined/8523 "2019-03-02T09:17:09Z")
**Showing post:** 9
### Author: ![Colin](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/colin/32/17040_2.png) [@Colin](https://discourse.nodered.org/u/Colin)
#### Post date: [2 March 2019 13:50 UTC](https://discourse.nodered.org/t/referenceerror-node-is-not-defined/8523/9 "2019-03-02T13:50:36Z")
If you wiped your home folder then it should have started with an empty flow. So you should not get the errors. The xaomi node will not even be installed.
_[View the full topic](https://discourse.nodered.org/t/referenceerror-node-is-not-defined/8523)._
