Referrencing msg.payload in JSON
Show us the complete text you are entering please.
Ok, excuse me, I've solved.
The right syntax was$.topic.
But I had to choose "expression" and not "json" in the to field.
Thank you.
cld
We would still like to see the complete question in context because a lot of people, including me, learn from this forum.
Ok, this is the wrong node:
[{"id":"98b6dbec.1356f8","type":"change","z":"d960624e.e361d","name":"create off","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t \"_id\": $.topic,\t \"screen\": \"off\"\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":220,"wires":[[]]}]
this is the good one:
[{"id":"eff8325f.f473f","type":"change","z":"d960624e.e361d","name":"create off","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t \"_id\": $.topic,\t \"screen\": \"off\"\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":100,"wires":[[]]}]
They look the same to me?
Bad:
 "_id": $.topic,
 "screen": "off"
Good:
 "_id": $.topic,
 "screen": "off"
@SteveMann the key difference is the type of the field. If you select JSON type, then you cannot do any sort of referencing of message properties - it is entirely static. If you select the Expression type then you can use JSONata expressions that reference message properties.
You already know that JSON formatting is my Achilles heel, but after importing the two examples, I see no difference between them. What am I missing?
@SteveMann I agree with you, they are both using an expression and both expressions are identical.
Yup, on inspection the nodes are identical. I'll give @ioclaudio the benefit of the doubt and put that down to copy/paste error given he's acknowledged he needed to use the Expression type rather than JSON.
Yes, my error was to use the wrong type for the field.
I used Json instead of Jsonata.
Wrong:
[{"id":"94f7be69.564c3","type":"change","z":"1802dedb.cf8d01","name":"create off","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t \"_id\": $.topic,\t \"screen\": \"off\"\t}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":160,"wires":[[]]}]
Right:
[{"id":"94f7be69.564c3","type":"change","z":"1802dedb.cf8d01","name":"create off","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\t \"_id\": $.topic,\t \"screen\": \"off\"\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":160,"wires":[[]]}]
cld
I need to pull a global variable using JSON how do I do that
@zenofmud @knolleary
@Zbrooklyn - seeing how this thread is two years old, it would be a good idea if you started a new thread and explained what you are trying to do and what you have done so far.
With that, I'm going to close this thread.
