# 🎉 Refresh tokens in node-red-node-dropbox (Now published as v2.0.0)
**URL:** <https://discourse.nodered.org/t/refresh-tokens-in-node-red-node-dropbox-now-published-as-v2-0-0/65610>\
**Created:** [25 July 2022 21:05 UTC](https://discourse.nodered.org/t/refresh-tokens-in-node-red-node-dropbox-now-published-as-v2-0-0/65610 "2022-07-25T21:05:11Z")\
**Showing post:** 15
**Post date:** [30 July 2022 21:41 UTC](https://discourse.nodered.org/t/refresh-tokens-in-node-red-node-dropbox-now-published-as-v2-0-0/65610/15 "2022-07-30T21:41:44Z")
> [@Paul-Reed](#):
> localhost didn't work for me either
Ah yes, now I remember.
My last proposal above to have the node always to use localhost, was pure nonsense...
As @Frida already experienced, the hostname in the dropbox redirect\_uri must match the hostname used to access the flow editor.
1. If you want to use _ **localhost** _ in your redirect\_uri, then you need to use the browser that is installed on that host. Because the browser installed e.g. on a raspberry, can access local resources on that same raspberry via localhost.
2. But normally if you access your flow editor via `https://my_rpi_name:1880/some_path`, then the redirect uri should be `https://my_rpi_name:1880/dropbox /authenticate`
Am I correct that there is only a problem for Node-RED systems that fulfill the following 2 conditions:
1. The system is **not** accessible via localhost, because there is no browser installed on that host.
2. And SSL is _ **not** _ enabled (via the Node-RED settings.js file.
Because dropbox requires https, unless you use localhost.
Not sure if there is anything I could do about that, to be honest...
_[View the full topic](https://discourse.nodered.org/t/refresh-tokens-in-node-red-node-dropbox-now-published-as-v2-0-0/65610)._
