# Regression Node - Help
**URL:** <https://discourse.nodered.org/t/regression-node-help/20597>\
**Created:** [19 January 2020 21:44 UTC](https://discourse.nodered.org/t/regression-node-help/20597 "2020-01-19T21:44:39Z")\
**Post date:** [19 January 2020 21:57 UTC](https://discourse.nodered.org/t/regression-node-help/20597/2 "2020-01-19T21:57:35Z")
Unfortunately your flow is not importable, please see below for how to fix that. You can edit your previous flow.
_[View the full topic](https://discourse.nodered.org/t/regression-node-help/20597)._
