# Remove duplicates from an array of objects
**URL:** <https://discourse.nodered.org/t/remove-duplicates-from-an-array-of-objects/28013>\
**Created:** [8 June 2020 21:07 UTC](https://discourse.nodered.org/t/remove-duplicates-from-an-array-of-objects/28013 "2020-06-08T21:07:26Z")\
**Author:** ![michaelblight](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/michaelblight/32/445_2.png) [@michaelblight](https://discourse.nodered.org/u/michaelblight)\
**Post date:** [9 June 2020 04:17 UTC](https://discourse.nodered.org/t/remove-duplicates-from-an-array-of-objects/28013/2 "2020-06-09T04:17:30Z")
I would take the lazy approach and use a function node.
var prev = null;
msg.payload = msg.payload.filter((item) => {
    var keep = (item.x !== prev);
    prev = item.x;
    return keep;
This assumes you only want to dedupe on 'x', and they are all in sequence. You would have to modify it a bit if that's not the case.
_[View the full topic](https://discourse.nodered.org/t/remove-duplicates-from-an-array-of-objects/28013)._
