# Return msg from ui\_template node
**URL:** <https://discourse.nodered.org/t/return-msg-from-ui-template-node/4651>\
**Created:** [7 November 2018 17:16 UTC](https://discourse.nodered.org/t/return-msg-from-ui-template-node/4651 "2018-11-07T17:16:55Z")\
**Post date:** [7 November 2018 17:21 UTC](https://discourse.nodered.org/t/return-msg-from-ui-template-node/4651/2 "2018-11-07T17:21:54Z")
Please read this post in sharing code on the forum and then edit your post to fix up the formatting. The XML is being treated as HTML and not displaying.
_[View the full topic](https://discourse.nodered.org/t/return-msg-from-ui-template-node/4651)._
