# Role based access
**URL:** https://discourse.nodered.org/t/role-based-access/28666
**Category:** General
**Created:** [20 June 2020 18:53 UTC](https://discourse.nodered.org/t/role-based-access/28666 "2020-06-20T18:53:21Z")
**Showing post:** 5
### Author: ![sarosh](https://avatars.discourse-cdn.com/v4/letter/s/f08c70/32.png) [@sarosh](https://discourse.nodered.org/u/sarosh)
#### Post date: [24 June 2020 16:13 UTC](https://discourse.nodered.org/t/role-based-access/28666/5 "2020-06-24T16:13:27Z")
Hi, Thanks to your reply, I created the below code to login using REST API. But when I login I cannot access pages. I have verified I get the _access\_token_ and get _role_ from it. Can you help or point what I am missing or doing wrong.
var request = require('request');
var jwt = require('jsonwebtoken');
const { valid } = require('semver');
module.exports = {
    type: "credentials",
    users: function (username) {
        return new Promise(function (resolve) {
            // Do whatever work is needed to check username is a valid
            // user.
            var valid = true;
            if ('admin' != username || 'user' != username) {
                valid = false;
            if (valid) {
                // Resolve with the user object. It must contain
                // properties 'username' and 'permissions'
                if ('admin' == username) {
                    var user = { username: "admin", permissions: "*" };
                } else if ('user' == username) {
                    var user = { username: "user", permissions: "read" };
                } else {
                    resolve(null);
                resolve(user);
            } else {
                // Resolve with null to indicate this user does not exist
                resolve(null);
    authenticate: function (username, password) {
            // Do whatever work is needed to validate the username/password
            // combination.
            console.log("Sending aunthentication request to keyclock");
            var options = {
                'method': 'POST',
                'url': 'https://auth.example.com/auth/realms/MyRealm/protocol/openid-connect/token',
                'headers': {
                    'Content-Type': 'application/x-www-form-urlencoded'
                form: {
                    'grant_type': 'password',
                    'username': username,
                    'password': password,
                    'client_id': 'node-red',
                    'client_secret': 'my-secret',
                    'scope': ''
            request(options, function (error, response) {
                if (error) {
                    console.log("Error authenticating: " + error);
                    resolve(null);
                    return;
                var bodyObj = JSON.parse(response.body);
                var jwtObj = jwt.decode(bodyObj.access_token);
                console.log("Got access_token");
                console.log("role: "+jwtObj.roles[0]);
                var user = null;
                if (jwtObj.roles[0]=='admin') {
                    console.log("permissions: *");
                    user = { username: jwtObj.roles[0], permissions: "*" };
                } else if (jwtObj.roles[0]=='user') {
                    console.log("permissions: read");
                    user = { username: jwtObj.roles[0], permissions: "read" };
                resolve(user);
    default: function () {
            // Resolve with the user object for the default user.
            // If no default user exists, resolve with null.
            resolve({ anonymous: true, permissions: "read" });
EDIT: It tuns out it is saving **username**. I checked by logging it in users function, but I a returning admin and it is saving the actual username. Is there a way to use local storage??
            // user.
            console.log("Verfying user: "+username);
_[View the full topic](https://discourse.nodered.org/t/role-based-access/28666)._
