# RSS feed on dashboard
**URL:** <https://discourse.nodered.org/t/rss-feed-on-dashboard/12603>\
**Created:** [26 June 2019 09:38 UTC](https://discourse.nodered.org/t/rss-feed-on-dashboard/12603 "2019-06-26T09:38:05Z")\
**Showing post:** 3
**Post date:** [26 June 2019 10:12 UTC](https://discourse.nodered.org/t/rss-feed-on-dashboard/12603/3 "2019-06-26T10:12:21Z")
Take a look at this example of how to build a table.
> [@EXAMPLE (template) - displaying a two dimensional table](https://discourse.nodered.org/t/example-template-displaying-a-two-dimensional-table/662):
> Problem: You need to display a table with first name, last name and age. Sample data: Paul Doe, 24 Greg Jones, 31 Able Smith, 29 We will use a function node to create the table like this: And display the table using the template node. Here is what we use in the template node: [09%20AM] In this case we use the ng-repeat twice, once to process each row of the table in the \<tr\> and once to display each item in each row using a \<td\> element. Here is what the display will look li…
You will also need to add a debug node to your RSS feed to see how the data coming out is formatted
_[View the full topic](https://discourse.nodered.org/t/rss-feed-on-dashboard/12603)._
