# RTSP Feed on dashboard
**URL:** <https://discourse.nodered.org/t/rtsp-feed-on-dashboard/92876>\
**Created:** [3 November 2024 05:03 UTC](https://discourse.nodered.org/t/rtsp-feed-on-dashboard/92876 "2024-11-03T05:03:06Z")\
**Showing post:** 6
**Post date:** [3 November 2024 16:43 UTC](https://discourse.nodered.org/t/rtsp-feed-on-dashboard/92876/6 "2024-11-03T16:43:53Z")
I would stick to the old for now for RTSP video, that works really well even if the flow looks complex in itself since Kevin maybe added more features in his sample then you actually need
I would make one tab per camera to keep a nice organized flow
We (@dynamicdave, @zenofmud and myself) made earlier an attempt using Kevins nodes together with others (and some coding...) to make a video management system for home usage. It is also supporting other video sources like http, youtube and recorded video. Could maybe be of interest to look at
[https://teamwork-int.com/hss/index.html](https://teamwork-int.com/hss/index.html)
> [@Home Surveillance System (HSS) - UPDATE and UPGRADE](https://discourse.nodered.org/t/home-surveillance-system-hss-update-and-upgrade/74699/7):
> Thanks @dynamicdave, Here's what I see after the chmod command: pi@nr-vid-sec:/var/www/html/hss\_media/recordings/09 $ ls -lt total 400 -rw-r--r-- 1 pi pi 47940 May 10 07:22 07-22-45.mp4.jpg -rw-r--r-- 1 pi pi 0 May 10 07:22 07-22-45.mp4 -rwxrwxr-x 1 pi www-data 38175 May 10 07:15 07-15-02.mp4.jpg -rwxrwxr-x 1 pi www-data 0 May 10 07:15 07-15-02.mp4 You can see that before the chmod command, both pi and www-data had ownership, but now when the app saves the files, only pi h…
_[View the full topic](https://discourse.nodered.org/t/rtsp-feed-on-dashboard/92876)._
