# Running Multiple Instances of Node-red using NSSM
**URL:** <https://discourse.nodered.org/t/running-multiple-instances-of-node-red-using-nssm/57127>\
**Created:** [24 January 2022 08:39 UTC](https://discourse.nodered.org/t/running-multiple-instances-of-node-red-using-nssm/57127 "2022-01-24T08:39:49Z")\
**Showing post:** 9
**Post date:** [24 January 2022 13:46 UTC](https://discourse.nodered.org/t/running-multiple-instances-of-node-red-using-nssm/57127/9 "2022-01-24T13:46:15Z")
The 3 minute delay can be caused by a known issue if your node-red instance does not have an internet connection or is behind a proxy...
> [@Node-RED v0.19.4 3 minute delay during startup on windows](https://discourse.nodered.org/t/node-red-v0-19-4-3-minute-delay-during-startup-on-windows/3798/15):
> Finally - node-red startup 3 minutes faster! For anyone behind a proxy having a 3 minute delay starting node-red... Using notepad/text editor, open node-red.cmd (look in you NPM Global folder) Add the following line to the top of the file (before any other command) SET NO\_UPDATE\_NOTIFIER=1 Start node-red using the cmd file node-red.cmd Enjoy the extra 3 mins slight_smileThanks to @hotNipi, @KarnanKurup for pointing me in the right direction .
_[View the full topic](https://discourse.nodered.org/t/running-multiple-instances-of-node-red-using-nssm/57127)._
