# Running node-RED as root
**URL:** <https://discourse.nodered.org/t/running-node-red-as-root/29889>\
**Created:** [11 July 2020 10:40 UTC](https://discourse.nodered.org/t/running-node-red-as-root/29889 "2020-07-11T10:40:01Z")\
**Post date:** [11 July 2020 11:21 UTC](https://discourse.nodered.org/t/running-node-red-as-root/29889/2 "2020-07-11T11:21:12Z")
Have a look at this link... (I run Amazon Echo on port 8980 as a NORMAL Pi user).
> [@Alexa Voice Command to start the flow?](https://discourse.nodered.org/t/alexa-voice-command-to-start-the-flow/15606/5):
> I've used nearly all of them include the offering Simon mentioned. I'm currently using this node... On my Echo Dot I had to run the following as I didn't want to start Node-RED as root. It routes port 8980 to port 80. You need to enter 8980 as the port number in the amazon-alexa-hub You need to run these commands on your Pi if your using a WiFi connection. sudo apt-get install iptables-persistent sudo iptables -I INPUT 1 -p tcp --dport 80 -j ACCEPT sudo iptables -A PREROUTING -t nat …
_[View the full topic](https://discourse.nodered.org/t/running-node-red-as-root/29889)._
