Nodes for Salesforce built with @bonsae/nrg
You can use it as a ref on how to write nodes with @bonsae/nrg
Claude Code understood pretty well the framework after pointing him to the docs and its repo. There are possible issues with what it outputed but now it is much easier to read the code, specially the client side since there is a standard to follow. It also worth mentioning that nodes authored with @bonsae/nrg and AI will likely use less tokens because it handles a ton of boilerplate.
