# Send values to an array, write to CSV when full
**URL:** <https://discourse.nodered.org/t/send-values-to-an-array-write-to-csv-when-full/11092>\
**Created:** [14 May 2019 04:09 UTC](https://discourse.nodered.org/t/send-values-to-an-array-write-to-csv-when-full/11092 "2019-05-14T04:09:27Z")\
**Author:** ![bakman2](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/bakman2/32/6207_2.png) [@bakman2](https://discourse.nodered.org/u/bakman2)\
**Post date:** [14 May 2019 08:28 UTC](https://discourse.nodered.org/t/send-values-to-an-array-write-to-csv-when-full/11092/4 "2019-05-14T08:28:52Z")
You didn't.
_[View the full topic](https://discourse.nodered.org/t/send-values-to-an-array-write-to-csv-when-full/11092)._
